trickflow 185x heads
Old Feb 18, 2010 | 12:26 PM
6801's Avatar
Default trickflow 185x heads
got it fired up, i dont know power numbers but it sound pretty impressive. comming from 9-10 second bracket cars that im use to. as soon as i get a few miles on it and broken in i plan on dyno tune so ill keep updadting.
Old Feb 18, 2010 | 12:45 PM
pyro719's Avatar
Got any vids? What cam?
Old Feb 18, 2010 | 05:47 PM
pillarpod's Avatar
Old Feb 18, 2010 | 05:53 PM
sepno77's Avatar
Congratulations 1st person to post that the heads are on and fired up.
Old Feb 18, 2010 | 08:32 PM
6801's Avatar
im working on it, comp 292fxi it ideles nice sounds like gm 847 cam
Old Feb 19, 2010 | 06:30 PM
fuel's Avatar
good choice....cant wait to here it run.....oh and dyno numbers too
Old Feb 19, 2010 | 07:01 PM
Spiers's Avatar
Congrats
Old Feb 19, 2010 | 07:55 PM
MasterTomos's Avatar
lets see sum pics and vids!
Old Feb 19, 2010 | 10:54 PM
6801's Avatar
it sounds good but it wont run out of its own way i drove around for a while two footing wants to stall out during breaking. it ideles at 1100rpm and revs good in neutral all day. im gonna get vids soon just been to busy working on it. im gonna check fuel pressure, its stock but it cant be that bad it has no pull and feals like a 15 second car. maybe the mail order tune is way off im gonna work on more tommorow plugs? no misses or surges it fired right upmaybe ill turn fuel pressure up im going to bed stumped its been a hard 2 weeks work.
Old Feb 20, 2010 | 12:39 AM
SoxXpupPeT's Avatar
i was looking at these heads for when i get to the point on my car. i hope they work well..
Old Feb 20, 2010 | 01:02 AM
vanilla89's Avatar
Does it have any codes?
Old Feb 20, 2010 | 01:14 PM
pyro719's Avatar
I think you may have over cammed your car thats a huge cam in a 350 hope you have a 4,000 stall
Old Feb 20, 2010 | 03:23 PM
6801's Avatar
it a m6 i think i found the problem. j haven got on it hard havant reved over 5000rpm i checked everything today took for a highway cruise car turned of after 10 miles and wouldt start. it cooled down and has no oil pressure had it towed home took of the oil filter and well looks like its trime for a full rebuild. what luck had no problemes previous so what luck. the 292xfi cam an't really that big its listed to 6200rpm so ill have alot of time for pics.
Old Feb 20, 2010 | 03:39 PM
ThreeHonks's Avatar
what actaully happened?
Old Feb 20, 2010 | 03:44 PM
pyro719's Avatar
That cam needs to be shifted @ 6800 +
Old Feb 20, 2010 | 06:09 PM
6801's Avatar
i guess ill have to build a 7000rpm motor. i have no idea what happened, i never got any coolant in the oil during disasembeley everything looked great on the engine stand even the cylinder bores. it didt overheat the car just turned off while crussing about 75mph and wouldt even crank for about 30 miin. i wish atleast it would of ran good so i can atleast no how the combo is. could it of leaned out the plugs look like they came out of the box. i guess i wont know until i take it apart anyone have any leads on a solid shortblock or a decent crank kit.
Old Feb 20, 2010 | 06:13 PM
jaycenk's Avatar
You have a budget in mind for the bottom end? You can spend 2k to 5k on it it just depends on what kind of cash you have for it.
Old Feb 20, 2010 | 06:15 PM
gixxer75094lt1's Avatar
who did the mail order tune?? sounds like how it was running before i had my previous car untuned with the 306 cam in it. after the tune it ran great. could it be a tuning issue perhaps?? well that sucks man, i mean u werent even getting on it or beating the **** out of it just tryin to break it in. let us know what u find out after the tear down.
Old Feb 20, 2010 | 06:50 PM
6801's Avatar
i wish i could of got on it, the tune was done by a very reppable lt1 person i dont want to say names. i want to just drive itmy budget ant very high after all this work so im proably goona have to do a cheap crank kit or budget 383 any links or suggestions im proably looking 2000 mark im not going for a max build just a reliable strong runner.
Old Feb 20, 2010 | 08:07 PM
jaycenk's Avatar
at 2k the best you can do is tear that engine down and see what is good in it and then have the block inspected and machined. If the crank and rods are still good you can do a 355 with a custom piston in it to match those heads. Even a cheap rotating kit for a 383 is still going to set you back about 1500. Best bet would be to take the engine out and have it gone through expecting to reuse the crank and rods. You can still get those exact rods and they are not to bad price wise and if need you can get a good lt1 crank for it but at that point it should really be ballanced by the machine shop. If they ballance it to 0 you are going to need to change flex plates or flywheel to a neutrally ballanced flex or fly. Pay close attention to this when you do what ever you are going to do because rotating kits that are pre ballanced are usually done to 0 and thats not how the stock bottom end is set up.
