How to clean the maf sensor
Old Feb 18, 2010 | 12:50 PM
2fast4u1989's Avatar
Default How to clean the maf sensor
hey guys i have a 1995 firebird formula. here is a pic of my maf sensor. do i need to pull it apart or can i just spray it with maf cleaner.
Old Feb 18, 2010 | 12:53 PM
RamAir95TA's Avatar
Make sure you use MAF cleaner designed for EFI, NOT carb cleaner. Try not to spray any directly on the heated elements of the MAF.
Old Feb 18, 2010 | 01:23 PM
MasterTomos's Avatar
you don't need to take it apart...just spray it in there, and again, make sure you use efi MAF cleaner, not carb cleaner.
Old Feb 18, 2010 | 02:36 PM
I8ASaleen's Avatar
Electronics or MAF cleaner doesn't always work, I would lightly use some brake cleaner and all of that junk will come right out.
Old Feb 19, 2010 | 10:23 AM
pillarpod's Avatar
Use MAF cleaner and make sure its dry before you put it back in
