Single Plane Build on Advanced Induction 385
Old Feb 29, 2012 | 10:24 AM
  #41
quik95lt1's Avatar
Originally Posted by azlt
This is an awsome setup, got any pictures of those angled spacers to make the intake bolts the correct angle? This is what i was planning on doing instead of having it machined i just am unsure of the angle i need, thanks!
if you look closer at the pic above you can see the little spacers between the head of the bolt and the intake on the front bolts........see?
Old Feb 29, 2012 | 12:17 PM
  #42
azlt's Avatar
Yeah i see but did you just eyeball it for the correct angle or did you have a way of measuring?
Old Feb 29, 2012 | 12:31 PM
  #43
quik95lt1's Avatar
i measured it i made a jig for the original intake in the bridgeport and found the angle with the head.......then i put the new intake on the jig and moved the head till the mill fit in the hole correctly.......the angle difference told me the angle i had to make the spacers for
