Trouble Replacing Valve Springs?! Help!
Also there is the thing that seems to be connected to the valve stem looks black, that holds the bottom retainer in, how do I remove this piece? ------>
Grab the valve stem from the exhaust port with a set of pliers and hold it up.
Now, PLEASE cover the valve spring compressor with a tower before you blow the top of it with a mallet to free up the retainers from the locks. You don't want the tool jumping off the spring as you whack it on the top and injuring you.
If you are installing beehives, be careful with that tool you are using. It has a tendency to slip off the retainers or the coils and you will have a spring flying across the room or worse, into your face. Again, just by using fingers to hold up the valves to keep them closed to get the valve locks in quicker and easier without needing to compress the springs too much.
Good luck.
I see your motor is on a stand so this will be easy. you can also air up the cyl to hold the valve up while you hit the socket to knock the spring lose.
those "things" that are black holding down the spring locators are called valve seals....replace them. Put new locators on if changeing spring type and then new valve stem seal.
might want to stuff paper towels in all those openings on the head....you would not be the first to drop a keeper inside the motor if you don't
When changing valvesprings with heads on, it is best to use compressed air to keep the valves on their seats. If you do not have access to compressed air a good trick is to run PVC hose through the spark plug hole and run the piston up to TDC. That will also keep the valves from dropping (make sure that the hose is long enough that you don't drop it into the cylinder or you will be pulling a head!). If you get control of the valves it will make it easier to tap the locks loose and to get everything back together.
i broke that gay *** handle off because when your really tightning some stiff aftermarket springs down it starts to take a toll on your hands. a 12 point 15mm socket fits on the top of the tool decently, i filled the socket with JB stick weld ( jb weld brand epoxy ) and stuck it on there so i could use a socket to tighten and loosen that tool and it saved me so much time and agrivation since i was doing this with the heads in the car. just fyi. and rotating the motor over to the cylinders TDC might be a little safer than rubber bands when it comes to dropping the valve in the cylinder
