Oil, Oil, Everywhere And More!! L@@K!
So I am about to start my underbody cleaning now that the motor is out, no sense in putting a clean and freshly painted and rebuilt motor back into a dirty car
So here is the before, Stay tuned for the after, Its a mess down there! (this explains my garages somewhat) ---->
Look for the after pics!
Also good news!
I got my PaceSetter Headers! They were at my front door 2 days after I ordered them! (I chose to go with the egr hookup), good quality and good welds, I'm probably going to wrap them before i put them on!----->
And I also got all of my valve springs off! check out how my build is coming along!!! ------>
And cleaned and decal-ed my hood! What do you think?! ----->
Also good news!
Thanks for the warning! would it make sense to buy a cold air intake and mount tubes where alot of people mount there fog lights?
at this point I am trying to squeeze every little bit of power out of the motor before I take it to get tuned!
IMO, just pick up a normal CAI like everyone else. Clean, simple, effective.
*Update!!!* Look What I found Under All that OIL!!! ---> what is this setup?!?!
And Here's an update On the Oil Problem... I Figured since I Had about a 1/4 inch of oil and grime left over from my idea of a "free oil Change
" I figured I would use something that could cut through grease like that, my conclusion a heavy duty degreaser... well it ended up being a little more heavy duty than I expected
take a look it stripped the paint! What do i do now? Hit the under body with a coat of clear coat? look ---->
after..... ----->
One side Vs. The Other.... -->
More coming.....
after..... ----->
More coming.....
But keep up the good work, it looks a lot better.....clean!!
