is lt1 worth it?
LS1 rated at 305hp 350tq (better engine in every way, responds to mods better)
Different years have different rating just average numbers.
You have to determine what is best for you. I chose the Lt1 because i feel the car is much better looking up front way more aggressive!
My mild mod list keeps me competitive with Ls1s with same mods thus however, my Lt1 is becoming a Ltx/Lsx hybrid
Larry
- JR
Higher HP rating
lighter motor
Bigger aftermarket for parts
6 bolt main
bigger/better brakes
many interchangable LS motors/parts
Easier to do Motorswaps (wiring/fitment)
LS1 cons:
Higher insurance
More expensive cars
Aftermarket may be larger, but that means more research(not to mention someone ignorantly modding the car before you buy it)
Aftermarket parts are often times more expensive
Many prefer the LT1 exhaust sound more than LS1
LT1 pros:
Cheaper cars
More low end Torque
Parts are often times cheaper
easier to research parts/results in LT1 aftermarket
Lower insurance
Great sounding Exhaust
LT1 cons:
less average factory HP rating
Older cars (harder to find in good/unmolested condition)
Not as fast in 1/4 mile factory
smaller aftermarket means less options
not as many people around with LT1 knowledge
Not as many interchangable parts with other cars/years
Optispark distributor design is many times problematic and labor intensive to change
(there's many more, but I feel these are the main ones)
Higher HP rating
lighter motor
6 bolt main
LS1 cons:
Higher insurance
More expensive cars
LT1 pros:
Cheaper cars
More low end Torque
Lower insurance
LT1 cons:
agreed. ls1 cars are getting cheap here though. depending on what you want to do with the car are how mechanically inclined you are is a huge factor. if i could do it all over again i would buy a blown up lt1 car. buy a 5.3cause i can get them cheap. cam it and put a t56 behind it. wouldnt be crazy fast but something good to beat on, but then again worked on cars for a living for along time.
Higher HP rating
lighter motor
6 bolt main
LS1 cons:
Higher insurance
More expensive cars
LT1 pros:
Cheaper cars
More low end Torque
Lower insurance
LT1 cons:
I personally wanted to keep a f-body and have another toy (c5/c6) after college and realistically I knew I needed to have the f-body be a bit cheaper (hence the LT1 97 ws6, although I like 98-02 ws6 looks better). However, I have fallen in love with the car because it was my first relatively quick car.
What are your goals within this f-body you are looking at? And what is your realistic budget?
