A noise, then zero oil pressure
So I'm already thinking worse case scenario, she told me yes it was still running when it was reading zero psi. What could instantly fail to cause this? Should I pull the fuse for ignition and fuel and try cranking it, see if I have pressure?
I'll try to get more details and such sorted out later in the day when I talk to her again. She says her husband put both oil and transmission fluid in yesterday.
None of them were built really. This motor is in her 94 Z28. Their 94 Formula had the stock engine go(166k?), then a H/C stock shortblock LT1(around 66k) go on them. Both of the Formula motors had knock.
This motor is a stock shortblock/heads with a CC503 and 1.6 scoripions. Around 127k on this one I think.
Guess I get to pull my 3rd LT1 of this year.
