problem making hp passed 4500
opti?????????????????????????????
Fuel pressure is the amount of pressure in the lines and rails upstream of the injectors.
If you have low fuel pressure, the motor will run fine until that low pressure keeps the injectors from adding enough fuel. Thus causing missfire/hesitation/breaking up in the higher rpms under load. The afr would be fine up until the point where it starts breaking up.
Now that being said your problem could very well be your optispark, but it takes about 15 seconds to hook up a mechanical fuel pressure guage to your schrader valve and check the pressure. As opposed to 2-3 hrs to change the distributor.
