Timing Chain Questions!
Old Feb 28, 2010 | 12:33 PM
boostedpower's Avatar
Exclamation Timing Chain Questions!
Okay so I have the cam in and did the pin (had to grind a little after knocking the pin in) so it fit in the gear of the timing chain, Now I see in this book and threads i need to use this degree angle finder thingy? is this necessary?! I can't find one of this ******* anywhere?! I have my springs on lubed up the cam installed that now I want to do my pushrods and rockers, im on a roll and really don't want to have to stop! HELP!
Old Feb 28, 2010 | 12:36 PM
PICS ----->
Old Feb 28, 2010 | 12:37 PM
SS RRR's Avatar
Village Troll
Angle finder thingy? Do you mean a degree wheel? If so, no you don't unless you want to degree your cam.
Old Feb 28, 2010 | 12:38 PM
RamAir95TA's Avatar
What is a "degree angle finder thingy?" If you mean a cam degree wheel, no.
What advantages does this have, yes a degree wheel sorry had a brain fart
Old Feb 28, 2010 | 01:19 PM
Problem! I Cant get them to line up perfectly, I have been trying for 45min now! it looks like its a tad bit loose, but I've tried moving a link one way and moving a link the other but it only makes them further apart! pics --->
Old Feb 28, 2010 | 01:29 PM
gregrob's Avatar
Turn the engine a little and that last pic will line up.
Did you put 1 or 6 at top dead center?
You can do either
Old Feb 28, 2010 | 01:37 PM
I duno!?! I thought you just had to line the timing chain dot to the crankshaft dot?!?! **** sorry guys, obviously my first build!
Old Feb 28, 2010 | 01:58 PM
What should it be at?! how do i get it there?! thanks guys! BUMP!
Old Feb 28, 2010 | 02:08 PM
JAKEJR's Avatar
In doing the dot to dot method, the #1 piston MUST be at ABSOLUTE TOP DEAD CENTER no matter what the dot shows. Sometimes there are errors in the placement of the dot on the cranck gear, other times it's the Woodruff key in the crank or the key slot itself that are off.
Everything flows from ABSOLUTE TOP DEAD CENTER. Dots are merely reference points which many times are off.
Of course if the crank dot is off by a little, everything else will be off too. That's why a degree wheel is used to find ABSOLUTE TOP DEAD CENTER for the number #1 piston, which eliminates the possibility of the crank gear dot being stamped a little or the Woodruff key/slot being off.
If you don't degree your cam you won't know.
I always use the Positive Stop method when searching for ABSOLUTE TOP DEAD CENTER since that method eliminates the piston dwell at TDC. Using a dial indicator to find ABTDC causes you the guess as to how much dwell there actually is.
After finding ATDC, the timing chain gear dot is aligned to that reference point. Of course, that T/C dot could be off too. The dot to dot method should be re-named to the "I'm willing to take my chances" method.
Finding ATDC is the key; the accuracy of all else depends on that.
Jake
Old Feb 28, 2010 | 02:54 PM
I felt air seeping out of the exhaust runners! the valves were still held in place, but i could hear and feel air leaking out on the exhaust side! what does this mean?! all the springs are in!
Old Feb 28, 2010 | 03:34 PM
SS RRR's Avatar
Village Troll
I don't get how it isn't lined up? You move it more clockwise and it'll line up just fine. The crank gear does not look to be straight up. You also have to take timing chain play into consideration. You are making this far more of a big deal than it needs to be.
Old Feb 28, 2010 | 03:36 PM
It will run like that just fine?
Old Feb 28, 2010 | 03:41 PM
SS RRR's Avatar
Village Troll
Run like what just fine? I'm not going to give you any guarantees on how it will run since I know nothing about your engine. It looks as though you have lined up the dots correctly. If you really want to be sure, go ahead and turn the crank gear to a true straight up position, take pic and post up.
Old Feb 28, 2010 | 04:10 PM
Badazz 97 TA's Avatar
dot to dot is #6TDC!! Jake is wrong!!! You better make sure you have your engine is in the right position before you go any farthur. Otherwsie your gonna have valves meeting pistons when you go to fire it up.
Dot to Dot =#6TDC (like in your pictures)
Crank dot 12o'clock Cam Dot 12o'clock = #1 TDC
Old Feb 28, 2010 | 04:19 PM
shbox's Avatar
Your crank gear dot is not perfectly at 12 o'clock (from what the pics look like). That is why it is not matching up perfectly.
31camaro's Avatar
if #1 is at tdc then the cam gear dot needs to be at the 12 o'clock position
Old Feb 28, 2010 | 04:21 PM
mdacton's Avatar
WTF are you talking about.............
WHOOOOOOOOOOOOOOAAAAA NELLLLLLLLLLLLYYYYYYYYY
Old Feb 28, 2010 | 04:26 PM
SS RRR's Avatar
Village Troll
Old Feb 28, 2010 | 04:36 PM
what do you guys mean???? whats to laugh at?
He has the timing set at #6 right now. Look at the pictures. He even said he doesnt know what piston he has at TDC. Thats what i was explaining on why he better make sure what piston he has at TDC with the timing set the way he does
http://shbox.com/1/4th_gen_tech2.html#cam_timing
