dyno sheet - does this look right?
This is quiet depressing.Dyno Sheet
Everyone I've spoken with agrees that something doesn't look right and the power off. the rwtq is embarrassing at 315 when stock I dyno'd at 265rwhp/296rwtq SAE
Could the tq converter be slipping at 5k rpms causing loss of power? The converter is the only used part I installed during the upgrade. Converter was also unlocked during these pulls since the only information we had was vig3200.
http://thunderracing.com/catalog/?ac...cid=73&sid=297
Without flow numbers and who ported them any guesses are completely random.
You need to get the car to a track and check your et/mph. Stalled autos dyno horribly, especially unlocked.
then look at the MPH that they lifted on the graph and compare to the RPM they lifted at.
I bet you are having converter issues...have a good friend that dyno'd 300ish rwHP on a nice little 383....after fixing the converter he made 420whp
and on the "tiny 185cc" comments....I made 422rwhp and 447rwtq with a 222/228 .544/.538 112lsa cam and ported LT1 castings with 188cc intake runners.
and on the "tiny 185cc" comments....I made 422rwhp and 447rwtq with a 222/228 .544/.538 112lsa cam and ported LT1 castings with 188cc intake runners.[/QUOTE]
Yes, but since you know your **** it is a given that your heads were professionally ported by someone who knew what they were doing. I did not mean to infer that the heads were too small to work, just that two heads can have 185cc intake runners and have a huge performance difference so that number does not mean much by itself.
We know absolutely nothing about his heads besides the runner size and that they are stock castings...I just find it silly trying to guess horsepower when we are missing info on the most important piece of the puzzle.
By the graph is is clear that he is having issues, but nobody has a clue what it "should" be making peak since we know zilch about the heads. They could be Billy Bob's Backyard Dremel'd heads and not be worth 5hp...we just don't know.
I'm not mentioning the shop that CNC'd the heads because I'm not going to start a this shop vs that shop flame war. these heads flow on the intake side 261 @.50 and 271 @.60 with exhaust in the 19X area. I do not have the sheet in front of me.
The cam specified should also make power to 6500 rpms instead it falls flat on its face at 6200 rpms. Converter slippage? that's what I'm beginning to thinks happening since this is the only used part installed along with only seeing 315 rwtq.
Considering the deal I got on the converter I'm leaning in that direction. The whole deal with the converter sale on here had a slight sour tone to it.
