Replacing opti
Old Mar 4, 2010 | 02:07 PM
BOLO's Avatar
Default Replacing opti
How much coolant to drain in order to remove the WP? Both side of the block have to be drained? Or just the radiator or both? Thanks for your input.
Old Mar 4, 2010 | 02:16 PM
fergymoto's Avatar
There is always some that stays in the lower part of the water pump and you are going to lose a little when you pull it loose from the block anyway, so I always just drain the radiator.
Old Mar 4, 2010 | 02:17 PM
duh's Avatar
duh
I just drain the radiator, then undo the hoses over a pan and then pull the wp off. I'm also a PITA as aI pull the fans out so I have more roon for my fat a$$ hands....I hate cutting myself....
Old Mar 4, 2010 | 02:50 PM
RamAir95TA's Avatar
Ditto.
Ditto. Pulling the fans is a piece of cake and makes for a MUCH easier swap.
Old Mar 4, 2010 | 04:13 PM
BOLO's Avatar
So, theres no neeed to drain the block? Just the radiator. And yes, I'll be removing the fan unit as well.
Old Mar 4, 2010 | 04:18 PM
duh's Avatar
duh
yeah, you don't need to worry about the block. A little will come out when you pull the pump off, but it won't be that bad. Just keep a pan under where the pump is and it should catch most of it.....Then pull the balancer, wires, opti and replace. Shouldn't be too much work...
Old Mar 4, 2010 | 04:51 PM
AChotrod's Avatar
I just drain the rad and pull the fans also. You could prob just pull the lowest hose on the pump
Old Mar 4, 2010 | 06:01 PM
Badazz 97 TA's Avatar
After draining the WP, i also unscrew the sensor in the waterpump. It helps to get more coolant out and it wont make as much of a mess when you remove the pump.
Old Mar 4, 2010 | 07:05 PM
BOLO's Avatar
Thanks everyone, appreciate all your help.
Old Mar 4, 2010 | 09:00 PM
SS RRR's Avatar
Village Troll
Do that w/ a full radiator and it'll make a huge mess.
Old Mar 4, 2010 | 09:04 PM
mdacton's Avatar
I just take it off and let **** pour everywhere cause im a badass
Old Mar 4, 2010 | 09:14 PM
jaycenk's Avatar
rofl
Old Mar 4, 2010 | 09:18 PM
wrd1972's Avatar
Do yourself a favor and fire the motor up without the water pump for a few seconds just to verify that the opti went on right. It wont hurt a thing.
Old Mar 4, 2010 | 10:06 PM
duh's Avatar
duh
good advice....you can actually run an engine without coolant for a decent amount of time.....
Back in the day we drained the oil and coolant on an SBC and then let it run 'til it blew.....took 2 hours before it actually let go completely....made hella noise first though.
Old Mar 5, 2010 | 06:57 AM
wrd1972's Avatar
There are some cool Youtube vids of this. Pretty funny.
