Roots Blower lt1
Old Mar 6, 2010 | 11:32 PM
zrocd's Avatar
Question Roots Blower lt1
i was just wonder if anyone could help me im building a supercharged lt1 and im not sure which roots blower to go with along with the cam. also im planning on keeping it street legal with fuel injected. thanks for your help!
Old Mar 7, 2010 | 12:36 AM
slownova73's Avatar
these threads might help you out. some serious work will have to be done, but it can be done!
here are all of his threads in order from first to last. alot of reading but its worth it!
http://www.ls1lt1.com/forum/showthread.php?t=1693
http://www.ls1lt1.com/forum/showthread.php?t=1820
http://www.ls1lt1.com/forum/showthread.php?t=2063
http://www.ls1lt1.com/forum/showthread.php?t=2246
http://www.ls1lt1.com/forum/showthread.php?t=3064
http://www.ls1lt1.com/forum/showthread.php?t=4493
http://www.ls1lt1.com/forum/showthread.php?t=14539
http://www.ls1lt1.com/forum/showthread.php?t=6860
http://www.ls1lt1.com/forum/showthread.php?t=4814
here is his video
http://s12.photobucket.com/albums/a2...nt=exhaust.flv
Old Mar 7, 2010 | 02:31 AM
I8ASaleen's Avatar
Unless you are amazing with fabrication I wouldn't even attempt it. Go for a centrifugal blower from Vortech or Procharger, better yet just go the turbo route and you'll be more than pleased.
Old Mar 7, 2010 | 02:46 AM
suicidal racing's Avatar
roots would be some work but not much..you would have to mod the hell out of the sb blower intake though
Old Mar 7, 2010 | 06:22 AM
duh's Avatar
duh
Shouldn't be that much work......
-Cut the water neck off and block the passages
-plug the Dist. hole
-convert bolt pattern (heads or intake..your choice)
-weld in injector bungs, and make custom fuel rails
-go with an LSx style Magnacharger (TB inlet up front....then use an LSx TB)
-Have Magnacharger build a custom jack shaft
-Run your pulley arrangement.
-Make a custom intake setup
This may require a cowl hood to clear, or you may get lucky and have it clear the stock hood.
In actuality I think it's easier than most think, but no one wants to try it because it will require some $$$ and fabrication and thinking outside the box. This is the exact plan for my 408 build once I can finally get the ball rolling (putting it off right now because of the $$ involved). It is doable, just requires some engineering to work.
Old Mar 7, 2010 | 12:43 PM
SS RRR's Avatar
Village Troll
Dyno numbers and lots of words.... Any track times?
Old Mar 7, 2010 | 02:05 PM
Originally Posted by duh
Shouldn't be that much work...... -Cut the water neck off and block the passages -plug the Dist. hole -convert bolt pattern (heads or intake..your choice) -weld in injector bungs, and make custom fuel rails -go with an LSx style Magnacharger (TB inlet up front....then use an LSx TB) -Have Magnacharger build a custom jack shaft -Run your pulley arrangement. -Make a custom intake setup This may require a cowl hood to clear, or you may get lucky and have it clear the stock hood. In actuality I think it's easier than most think, but no one wants to try it because it will require some $$$ and fabrication.
well you are planing on useing a screw with the magnaflow..he said roots so im thinking a roots blower like 8-71 or 10-71....an if doing that he would want to run a distributer or atleast i would..stock fuel system wont work and he would need to go with a bs3 or fast to controle the injection..its way cheaper to just run dual 650 carbs and easier..he would have to mod the water neck
Old Mar 7, 2010 | 07:38 PM
bbk's Avatar
bbk
Default Whipple 175 ax LT1 Phase II update!
I'm getting closer to having phase II done! Check it Out!
http://www.corneltechweb.com/superchargerphaseii.htm
Hope you enjoy!
Old Mar 7, 2010 | 08:06 PM
slownova73's Avatar
^^^ nice stuff right there!
Old Mar 7, 2010 | 08:27 PM
hotrodscrap's Avatar
I love it! Nice project, all the hard work would be worth it.
-SS
Old Mar 7, 2010 | 09:34 PM
brokenbird's Avatar
Hope you enjoy!
do you plan to make more?
Old Mar 7, 2010 | 09:49 PM
Revelation Z28's Avatar
if i still had my 94 and the 2-3k to do this, i would love to have a setup like the guy on ls1lt1. TB out the side and pulley in front ftw
Old Mar 8, 2010 | 06:17 AM
duh's Avatar
duh
Correct, I just throw them all in the same category since they all pretty much work on the same principals.... But a big roots blower as you're stating would be a royal PITA to get to work and be "decent" on a small cube motor (FWIW, I believe roots should only be put on big blocks, they just look wrong an a small block anything). And I would think a stock "style" fuel system could be used aside from a bigger pump and lines....the stock computer would most defitely be the stopper from making big power. You could even go to the LSx pcm and be able to run it nicely.
Old Mar 8, 2010 | 12:45 PM
bbk's Avatar
bbk
Cool Planning to make more?
Yes, this is why it has taken this long to come up with complete drawings and tooling to make more! I have to test this one first before I will feel comfortable selling more! I will keep my site updated with my progress.
Cheers!
Old Mar 8, 2010 | 03:33 PM
BigBadWhitey's Avatar
Cheers!
Score. If theres a waiting list, put me on it.
Old Mar 8, 2010 | 05:25 PM
bbk's Avatar
bbk
Arrow Waiting list!
If you are interested in joining the waiting list then just e-mail me at info@corneltechweb.com to put yourself on it! Include your full name please! Thanks!
Cornel
Old Mar 8, 2010 | 07:39 PM
LT1 Z/28's Avatar
Cheers!
Wow this is awesome!! Do you have an estimated time frame when your plan on selling if you decide to sell it? and Yea selling the whipple with it or just the parts to mount it? Sorry for so many question just a little excited lol
Old Mar 11, 2010 | 09:15 PM
bbk's Avatar
bbk
I am planning to have product available mid July. I will sell the intake manifold, base plate, bypass assembly, fuel rails, throttle body elbow all for the Whipple 175AX.There are options for a custom base plate for other SC's. You will have to purchase the Whipple direct since there would be no savings to bring it to Canada first and then send it back to the US.
http://www.corneltechweb.com/manifol...-rails%205.JPG
Kindest Regards,
Cornel
Old Mar 11, 2010 | 09:29 PM
Kindest Regards,
Cornel
Your in Canada?!
Sweet, ill definatly be a customer. Any idea what kind of price range this is looking at?
Old Mar 12, 2010 | 09:07 AM
LT1 Z/28's Avatar
Kindest Regards,
Cornel
Wow thats awesome, you the man Cornel. Its great to see one of these kits available for the LT1. How much did that whipple run you? So will we get a notification once you make a kit avalible or do you want us to email you to be put on a notification list?
