new to the forum
Old Mar 7, 2010 | 10:10 PM
killerbird95's Avatar
Default new to the forum
i bought a 95 formula firebird with a 4L60 trans. i'm wondering for one what is the stock 1/4 mile times for these cars. for two where do i start with my mods. this is my first gm fuel injected cars.
Old Mar 7, 2010 | 10:14 PM
Z28Camaro30Ann's Avatar
Look at the bolt-ons sticky at the top of the LT1-LT4 Forum for mods...
For your stock times, it varies according to altitude...where are you located?
Old Mar 7, 2010 | 10:15 PM
bigj2717's Avatar
It'll probably run mid to low 14s depending on the condition of the drive train. Start with the basic mods cold air intake, headers, exhaust and good stall, and a good tune then move on to the suspension stuff
that bolt ons post is in the LT1 Newbies Sticky
Old Mar 7, 2010 | 10:17 PM
i live in south carolina. how does these formulas compare to the mustangs and the ls cars
Old Mar 7, 2010 | 10:18 PM
bigj2717's Avatar
Yeah it just seems to me that a lot of newbies refuse to read the stickies. But yeah like he said read the stickies they will help you a lot also the search will be your friend in this forum
Old Mar 7, 2010 | 10:19 PM
jaycenk's Avatar
RPO codes are on the driver door. Pull them and decode the car then post what rear gear and someone can tell you almost down to the tenth. Mods? how many miles? what kind of power do you want to make? cold air intake for starters, Stall, headers, all the bolt ons.
Old Mar 7, 2010 | 10:28 PM
the car has 131k miles. i'm thinkn hard bout rebuilding it/ but i was also told i'd be better off droppin a ls1 in it. my trans guy said it should have like a 3.55 gear. i'm just lookin to run like low 11s high 10s in the 1/4. alot of the guys we run on the streets run vetts, ls cars, mustangs ect.
Old Mar 7, 2010 | 10:32 PM
bigj2717's Avatar
It'll will be a lot easier/cheaper to rebuild your motor then it would be to put in an ls1. Most autos either came with a 2.73 or 3.23 rear end 6-speeds came with 3.42
If it is stock gears more like 3.23's or 3.42's...I doubt 3.55's...
With 131K its up to you but I suggest starting over...do a 355 rebuild and go up from there...better safe than doing cam, etc and spinning a bearing or something fun like that!
Old Mar 7, 2010 | 10:33 PM
old93camaro's Avatar
no 3.55 maybe 3.23 or 2.73 depends on RPO code
Dont go LS1...we LT1 guys are proud lmao...We can take an LS1, we already have better low end power, just gotta do some top end work and we make them out slaves hahaha......ok ok, LS1's are mean too, sorry, but its still fun to beat on em when we can haha
Old Mar 7, 2010 | 10:36 PM
whats the difference in a regular 350 block and the lt1 block. cause id like to do the 383 with the dart pro 1 heads 205cc intake.
Old Mar 7, 2010 | 10:38 PM
from what i've read is that they dont really make a descent intake manifold for these motors. so thats the biggest weak point.
Old Mar 7, 2010 | 10:46 PM
bigj2717's Avatar
Lt1s use a reverse cooling system so that makes heads and everything different from a regular small block. The stock manifold are not too bad with a little port work another option is a small block single plane adapted to the lt1
Old Mar 7, 2010 | 10:47 PM
The intake manifold can take alot, you just have to port it. The LT1 is a REVERSE FLOW cooling engine....WAY different cooling than a SB350.
