What vacuum line can I tap into?
I want to add a device that runs off of vacuum so I need to tap into a vacuum line but I want to know what line I can tap into without messing up the engine or any values. Thanks
i would assume so. I do not no know to much on this part. But it would make sense. I know when my intake manifold rear seal busted i lost vacuum when I applied the brakes at low rpms. I had no issue at higher rpms. So yes i would say the vacuum increases with rpm range. Sorry for the long justification to my opinion.
