new engine break in
Pay attention to whats in the oil when you change it
When you change the oil, you need to slice the oil filter open and look a whats inside. Its normal to have some tiny metal slivers and gray looking stuff so dont freak out however you should not see this stuff in the second used filter. If you see lots of gold flake, thats very bad and the motor is coming back out.
http://www.mototuneusa.com/break_in_secrets.htm
I put Oil and regular Water in mine, let it get up to normal operating Temp at idle RPM. Shut it down, came out the next morning when it was cool, did the same, shut it down, did the same that night, shut it down.
The next morning I changed the Oil, drained the water, put 50/50 Coolant in it, and started driving it varying the RPM's. I changed the Oil at the 250mile mark, the 500 mile mark, the 1K mile mark, the 3K mile mark, and it is currently sitting with a little over 4K miles on it. I've been hammerin on it since the 750 mile mark.
When I get back from Iraq I'm changing the Oil again, mainly cause it will have been sitting for over 4 months..
...however running the engine for 10 min at initial start up is needed for multiple reasons.
2k RPM keeps oil pressure up vs. idle
engine needs to come up to full op temp
check for leaks
monitor the "sound" of everything
bleed cooling system
^^ all this and more basically takes about 10 min if all goes well
change oil and filter. there will be assembly lube and minimal debris in the oil
start motor and idle to operating temp while looking everything over.
drive in a low gear (1st or 2nd) with RPMs to 4k and then let the motor brake itself. repeat getting up to 5k. Do this about half a dozen times.
this "loads" the pistons and will set the rings. then drive the car and don't ***** foot around
500 mile oil/filter change
