oil sending unit
Old Mar 10, 2010 | 11:20 AM
jeffs93z28's Avatar
Default oil sending unit
Everysince I have owned my car, the oil pressure guage has been stuck at pegged out. I put it on ramps and saw that the connector on the unit had no wires going to it. Then i found a brown wire hanging by itself that had been stripped out of something. How many wires does the oil sending unit connector have. Thanks.
Old Mar 10, 2010 | 11:32 AM
tdevil55's Avatar
The brown wire is possibly the ground wire. Cant remember what the color of the wires for the OSU. From what I know, when the gauge is pegged out, then something is not grounded or one of the wires for it has been pinched or cut.
Old Mar 10, 2010 | 12:00 PM
jeffs93z28's Avatar
yeah, the tip got ripped off. It is supposed to have a tip on it something like the 02 sensors from what I can see. But it looks like it would only take that brown wire like the 02 only have one wire. I'm not sure though because I have seen another one yet. Does anyone have any pics that shows there sending unit with the wires on it? That would help a lot. Thanks.
Old Mar 10, 2010 | 12:13 PM
RamAir95TA's Avatar
The oil pressure sensor is a 1-wire sensor that grounds itself to the block. If it always reads high pressure, then the circuit is open. Reconnecting the tan wire should fix your problem.
Old Mar 10, 2010 | 12:55 PM
jeffs93z28's Avatar
Thanks a lot ramair, I just got to find a way to connect it now since the end was stripped off. Probably have to find an end in the junk yard.
