1.65 rockers
Personally, I'd stick with 1.6'ers as it will give you some safety room.
BTW, OP, If you're looking at CAT rockers, don't bother. I had a set in my hands marked 1.65 and they measured the same as the Crane Gold 1.6's. When I noticed the pushrod/head clearance the same as with adjacent Crane rockers still installed, I measured them and quickly got rid of them. No sense in running an inferior part for no potential gain.
Seems logical doesn't it? Unfortunately it doesn't work that way.
Nope. I've read this mis-information before, but it "ain't" so. The amount of preload doesn't effect valve lift. There are things that do but preload isn't one of them.
No matter what preload setting you use, the lobe lift multlipled by the rocker ratio, less any deflection will lift the valve the same amount.
Jake
jake is right though and pat knows what he's talking about... I think key questions here would be what springs are you running, and what is the installed height? This will determine what a safe amount of lift is for you to run. Generic statements like 1.8 installed height, and ".20" from "max" lift don't work here, sorry.
