comp cams techline sux. got a quick question
i just bought a 396 lt4 with a custom comp cam 236/244 .585/.580 112. it has 1.5 rr on it. i want to switch to 1.6 rr. iv been told that depending on the ramp speed on the lobe, i could start breaking rockers. i dont think that sounds right but wanted to find out for sure before i find out the hard way.
also, those cam specs are with a 1.5. what would they be with a 1.6?
Never heard of a broken rocker because the lobes were too steep...
.624 is a lot of lift for a street car, and may not even benefit you if the heads stop flowing at .600.
Honestly I would leave the 1.5rr's on unless you have killer heads. Depending on the lobes used you could eat up springs or encounter valve float at high rpms with the 1.6rr's.
Good luck, Ed
and for the record, i never believed it would hurt anything. i just wanted to be sure. i have never heard of that happening
The lift won't be the only thing that increases, everything happens faster so spring requirements will go up. On an HR you cannot run crazy high spring pressures like you can on a solid roller setup to keep the valves in check(or else you'd crush the hyd lifter), and you will need very good quality springs to survive a lot of street duty with over .6 lift and an aggressive lobe.
It can be done of course, but on an HR setup you have to be very careful of your spring choice and check the ramp rate of the lobe being used.
I still do not think the change from 1.5's to 1.6s would warrant the possible purchase of new springs and rockers. For less money then a high end set of springs and some roller rockers would cost you can have a new cam ground for the 1.5rrs you already have, and accomplish more for less.
I'd be very surprised if you gained anything at all going to 1.6's at this point; certainly not worth the expense of making sure it works without damaging something.
Whether your cam is the old Magnum lobes or the XE lobes, your cam/lift/duration is not holding you back at this point.
Wait until the plans for AI heads pan out; THEN optimize your cam/rockers'
Edit: Oh, and don't count on any worthwhile info from Comp's "tech" line unless you happen to know one of the 2 or 3 people there who are actually qualified to disseminate that kind of information. Comp has great products, but you'd better know what you want BEFORE calling them!
Intake is an XE lobe, not sure on the exhaust. run the 1.6s if the springs can handle it, otherwise throw some 1518s in there and you'll be fine.
