Door stuck locked!?
Old Mar 15, 2010 | 10:04 PM
z2895's Avatar
Default Door stuck locked!?
my passenger door on my 95 z28 is always locked! the only way i can open the door is to hold down the unlock button on the door. So when people r in my car they think im locking them out and they cant get out unless i hold down the button lol. Anyone have this problem and what needs to be fixed?
Old Mar 15, 2010 | 10:52 PM
Drew24's Avatar
Have you tried to take the door panel off ? see if there is anything out of the ordinary in there
Old Mar 15, 2010 | 11:07 PM
z2895's Avatar
ya i did. looked real good and dint see anything wrong. all of the linkage and all looked good.
Old Mar 15, 2010 | 11:15 PM
Drew24's Avatar
Hmm so does it unlock and lock back *** soon as you let go?
Old Mar 15, 2010 | 11:32 PM
ebeard's Avatar
Sounds like pulling on the handle might be causing it to lock back. That would explain why when you hold it it keeps it unlocked. something similar happens on a buddys camry, no clue how to fix it.
just be glad your window motor isn't going out they aint no fun
Old Mar 16, 2010 | 01:46 AM
the_merv's Avatar
Sounds like the Linkage is not adjusted properly..
Old Mar 18, 2010 | 05:49 AM
z2895's Avatar
the linkage and everything looks fine. i cant even open the door from the outside with the key. i cant even pull the little lever thats right under the handle inside to open it. so the only way to open that door is when i hold done the button and have to pull the handle at the same time. no other way i dont understand. it use to work then one day it stoped
