Another 383 question...
Old Mar 17, 2010 | 08:24 PM
Quasar94Z28's Avatar
Default Another 383 question...
So I have a 93, 383 motor in my 94 camaro (not running yet, but its in place) and we are running into an issue...the opti is different. I know that on the 93 it has an updated "vented opti" but shouldn't it still have the same plug? I was under the impression that 94-97 was the same. What do i have to do to make this work?
Thanks to everyone for all the help in getting this motor together
Old Mar 17, 2010 | 08:39 PM
blk6speed's Avatar
i think 92-94 are the same ..
old93camaro's Avatar
93-94 the same use spline gear 95-97 the same uses drool pin so if you have the wrong opti you have to get the one for that year....hope that helps
Old Mar 19, 2010 | 09:09 PM
this is an unrelated question but i didn't wanna start a new thread about this build...but I am removing my smog pump...and I was wondering if there is a belt that is the correct size that would completely bypass that pulley...or if I have to get a AIR pully bypass kit?
Sorry if its a stupid question...this is my 1st motor swap so I dont know much about it
Old Mar 19, 2010 | 10:11 PM
MasterTomos's Avatar
the AIR pump is electric, yur serp belt does not run to it. just rip that bitch off and yur good to go...
Old Mar 19, 2010 | 10:19 PM
who_needs_maf?'s Avatar
What he said. As far as the opti, 92-94 are the same and 95-97 are the vented style
Old Mar 20, 2010 | 12:06 PM
wow im an idiot. Thanks guys
Old Mar 20, 2010 | 10:56 PM
