need help with rockers
Old Mar 17, 2010 | 09:12 PM
06hemi's Avatar
Default need help with rockers
im thinking of buyin a set off 1.65 roller rockers is there anything special about them apposed to 1.6s im still running the stock cam in my 93 z28 what would the lift difference on a stock cam over the factory 1.5s
Old Mar 17, 2010 | 10:48 PM
thehammer69's Avatar
Divide your current lift by your existing rocker ratio and then multiply by the new ratio.
Old Mar 17, 2010 | 11:38 PM
06hemi's Avatar
that puts the factory cam at 516 lift do i need to get diffrent springs or push rods the 93 comes with hardwned rods tho so im thinking they are good
Old Mar 17, 2010 | 11:40 PM
massconfusion's Avatar
You're def. going to need springs
Old Mar 18, 2010 | 12:19 AM
jaycenk's Avatar
+1 on springs
Old Mar 18, 2010 | 12:54 AM
06hemi's Avatar
what kind witch ones for a reasonable price
Old Mar 18, 2010 | 03:27 AM
suicidal racing's Avatar
from my understand ls6 springs are drop ins but need comp 787-16 retianers and a cheap way to be able to run 1.6 rockers..ls6 yellow springs are max lift of .550 i read this on a diff site ls1lt1 in lt1 tech
Old Mar 18, 2010 | 04:31 PM
JAKEJR's Avatar
How'd you come up with that?
Jake
Old Mar 18, 2010 | 07:12 PM
06hemi's Avatar
thats what it says on here
Old Mar 18, 2010 | 08:13 PM
gregrob's Avatar
Not just 93's.... I don't know why people keep repeating that....
94's do too, but you should always check them with a file to be sure
Old Mar 18, 2010 | 08:52 PM
im not sure how you got that number..but you are wrong..factory cam is .450/460 for lift in 93-95 camaros..so with a 1.65 rocker that gives you .495/.506 for lift an 1.7 is .510/.521 which is what ill be running
