Bearing wear and piston mark
heres the piston
Pictures are kinda hard to see (or my laptop screen sucks)
The bearings look like its just wearing the coating off..
As for the piston it is normal for the piston skirts to have those marks because of the way the piston goes up and down and the side wall pressure the rods puts on it...
glad to hear that the wear on my skirt is normal. all should be well then
crank is a forged eagle 3.725
thanks for all the replies
the top end was stock. im think compression the guy told me was 11.5:1 i believe is what he told me. but that guy seems to not know much and this car was just thrown together. hell the bolt that holds the hub onto the crank was not even there. i mean i keep finding things i need to fix, another reason i wanted to take everything apart and just put it back together myself
definitely having them check everything before they even touch it with anything. gonna make sure this wont happen again if the rings are the cause. ill pull rings off tomorrow.
