Rebuild Kit
Old Mar 20, 2010 | 07:32 PM
importben's Avatar
Default Rebuild Kit
Anyone know where i can get a stock rebuild kit plz.. just trying to get car already.. not going for a huge rebuild because i plan to sell later..
Old Mar 20, 2010 | 07:35 PM
whytryz28's Avatar
Summit sells one.
Old Mar 20, 2010 | 08:27 PM
BigBadWhitey's Avatar
Any idea on the quality of the federal mogul ones from summit?
Old Mar 20, 2010 | 08:41 PM
who_needs_maf?'s Avatar
summit or jegs. Prolly not a bad kit you mentioned if you're just going for a stock rebuild kit
Old Mar 20, 2010 | 11:08 PM
How do you think itd do for a 355 rebuild expecting some performance? around 400rwph?
Old Mar 20, 2010 | 11:46 PM
If you wanna make 400 rwhp you'll need a set of good flowing heads and an intake and cam to match them. At that level I'd go with forged pistons and arp rod bolts at the very least. As for the quality of the summit or jegs kits I couldn't really tell you
Old Mar 20, 2010 | 11:49 PM
whytryz28's Avatar
They sell a Forged kit with Federal Forged pistons at Summit for around 500 iirc.
Wouldn't be bad, if you throw a cam at it and call it a day.
Old Mar 21, 2010 | 12:06 AM
Id be getting a new comp cam kit with rockers and springs and whatnot, forged flat tops with valve reliefs, arp rod bolts on stock rods and crank (ground crank 0.010) and have a local shop port the heads, 2.02/1.56 valves ect.
Old Mar 21, 2010 | 07:13 AM
96capricemgr's Avatar
400+ has been done on the stock shortblock many times.
Calling Comp and ordering a cam kit and having a local shop put 2.02 valves in is NOT part of the proper recipe.
Old Mar 21, 2010 | 12:23 PM
What would be a decent "recipie" then without spending 2grand on an AI/LE setup?
Old Mar 21, 2010 | 12:32 PM
bleakdragonmage's Avatar
Nitrous
Old Mar 21, 2010 | 12:57 PM
Yeah nitrous is really the only way without spending money on a good heads / cam combo
Old Mar 21, 2010 | 01:25 PM
Look 400+rwhp IS doable on stock displacement, but it is not as easy as people seem to think.
A few cars do it and now everyone thinks they can call Comp get some TERRIBLE advise from them, let anyone who can push the lever on a die grinder attack the heads and they think they will get there.
2.02 valves done right wont fit the stock seats, meaning wasting money on new seats.
People like to pretend a good result is expensive, well many of us who have figured out how to get a good result learned the hard way that a mediocre result often costs MORE. Doing things right and doing them once is cheapest.
Comp's tech line is BAD for the LT1, Comp has some great products and great engineers BUT the goober answering the phone is more likely to misslead you than help you. Comp's rpm ranges being WAY WAY off for the LT1 is well documented. They will sell you a cam they claim is good to 6200rpms but in an LT1 it wont yet peak at 7000rpms and because of that the spec'd springs will allow float. Not saying these are bad products, just that Comp's tech line will have you missapplying them. Put that same cam in a dual plane intake gen 1 and the springs and rpm range will be inline.
Not all local shops will be good with the high efficiency small ports of the LT1 heads, you might stumble on a winner or you might ruin a pair of castings.
No I would not spend $2000 with LE.
Yes I have spent over $2000 with AI as have many former LE customers once they see the truth.
As said above you can spend good money on heads and cam or try to get away cheaper with nitrous, for a modest 400rwhp goal I would not rebuild the shortblock for either option. The bottomend contributes relatively little to power compared to the topend.
Old Mar 21, 2010 | 07:30 PM
slomarao's Avatar
only let someone with LT1 knowledge port LT1 heads. Otherwise you will spend quite a lot of money for a toss up of results.
Old Mar 21, 2010 | 07:51 PM
Honestly if the shop has genuinely good results with the gen 1 Vortec heads they can probably handle LT1 stuff as well. Those are based on the LT1 iron heads so they are a small volume high efficiency port.
I would avoid a shop that likes 202 fuelie or camel hump heads like the plague though.
There are a lot of good porting shops all over the country, and a lot of bad ones too and you can't always rely on word of mouth to separate them. LOTS of folks give good reviews to a bad product just because they don't know any better yet.
Old Mar 22, 2010 | 08:05 PM
importben's Avatar
ok back to subject... this look like all i need??.. besides rods.. which i already priced..
http://www.summitracing.com/parts/FE...-000/?rtype=10
