LT1 Alternator Relocation Bracket Problem
Old Mar 22, 2010 | 02:15 PM
McAllenSuperSport's Avatar
Default LT1 Alternator Relocation Bracket Problem
My cousin installed his Alternator Relocation Bracket on his 1995 Trans am this past weekend. He took it out for a drive and at around 2000rpms or higher, it squeals like crazy. He thought it may have been the bearing in the alternator so, he lubed the bearing and reinstalled the alternator. Well it didn't help, it squeal even more. So he replaced his alternator thinking it was bad. Well the same thing happened. My question is, is there a certain way on installing this bracket? It didn't come with instructions. He ordered it from PCMforless.
Old Mar 22, 2010 | 02:38 PM
NSTIGATR's Avatar
change out the belt possibly. check for alignment issues between the pulleys. i had to use a washer behind my crank pulley to line it up with my alternator. it was out just a smidge though.
Old Mar 22, 2010 | 03:04 PM
Elliott's94Z's Avatar
Welcome to the club. I recently relocated mine and it squeaks at the initial start up then quiets down until I drive and turn corners. I have gone with 2 different belt sizes w/ no luck. I'm still looking into what is causing it. I will keep you posted if I find a solution.
P.S. Until then turn some Slayer on and it will hinder the noise.
Old Mar 22, 2010 | 03:10 PM
zlicious94's Avatar
ROFL! I like the slayer idea with all of the dam squeaks and rattles on these fbodys!!
Old Mar 22, 2010 | 03:25 PM
garage_queen's Avatar
same problem here.....I've got the old design from Speed Specialty and the thing has been a squealer since I put it on. I recently put a new belt on and it only got louder.
Anyone have a good way to check the alignment of the pulleys. Just looking at it, it appears to be lined up but the squeal and the powdered belt dust all over my a/c dryer and battery tell me it's not.
Old Mar 22, 2010 | 03:30 PM
My cousin text me right saying he just ordered a 6 rib 33" long belt. he is using a 5 rib belt. Let see what happens.
Old Mar 22, 2010 | 05:00 PM
Mine appears aligned. Not having the dust issue on the other hand.
Old Mar 22, 2010 | 05:53 PM
suicidal racing's Avatar
well easy way to check if aligned would be a straight edge an a level..belt squeaks i have fixed in the past is with sand paper..take some and sand on the pullys to give the pully some teeth to grab onto the belt with..check tension also..a belt squeaks because its sliding on a pully..
Old Mar 24, 2010 | 11:08 AM
Any word?
Old Mar 24, 2010 | 11:56 AM
enjoi355's Avatar
lmfao @ the slayer comment!!! i got a relo bracket from a sponsor over at ltxtech.com, at first my belt didnt squeak, but now every once in a while it does, i think its just normal for me cause it doesnt have a tensioner, and after a while it gets a little loose too
Old Mar 24, 2010 | 12:06 PM
AChotrod's Avatar
Mine hasnt made a peep yet. Knock on wood!!
Old Mar 24, 2010 | 03:24 PM
My cousin said, the belt I mentioned up top did not work.. I just don't understand why it keeps squeaking..
Old Mar 24, 2010 | 07:50 PM
Well aren't you f-ing special I will figure this little bastard out one way or another.
Old Mar 24, 2010 | 08:17 PM
97Z28SS's Avatar
I guess I'll find out in the next few weeks when my new engine is finished and in the car. I have the newest version which relocates the alt but keeps the ac and ps, which setup is everyone having the belt squealing issues with?
Old May 8, 2014 | 06:01 PM
StangEaterSS's Avatar
Mine squeals like hell on start up and after a burnout when the rpm comes down to idle. nothing fixes it.... ugh.
Old May 12, 2014 | 08:24 PM
LandcruiserNZ's Avatar
while the belts off its always worth checking all the pulleys and idlers are spinning freely and working properly I've had the odd one freeze up with a seized bearing
Old May 12, 2014 | 08:31 PM
hypno92's Avatar
My alternator was squeaky. I changed the serpintine belt and that resolved that issue 16 dollhairs
