Best Header Gaskets
Old Mar 24, 2010 | 08:58 AM
illusions's Avatar
my headers do not use gaskets. manufacturer recommends black rtv only. no leaks
Old Mar 24, 2010 | 07:20 PM
thehammer69's Avatar
If you are going to use RTV as an exhaust sealant...you really should have used a copper RTV such as Permatex Ultra Copper. It is specifically designed to seal in an extreme heat environment unlike black RTV.
Old Mar 24, 2010 | 07:21 PM
bigj2717's Avatar
Yeah the copper one works good but black is not ment for high heat
Old Mar 24, 2010 | 08:37 PM
95mysticta's Avatar
Well i just picked up the Mr Gasket Ultra Seal 5903s so lets just hope these work better then the bullshit coppers that wouldnt seal for anything on me. Ill let you know how they work in the next day or two.
Old Mar 24, 2010 | 08:41 PM
6801's Avatar
i buy to sets of fellpros and copper rtv them together never leak.
Old Mar 24, 2010 | 10:08 PM
RamAir95TA's Avatar
@ RTV on headers. Why would you muck that **** up when a dry header gasket does the same exact thing?
Old Mar 24, 2010 | 11:03 PM
pillarpod's Avatar
they crazy
Old Mar 25, 2010 | 08:12 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
I used Percy's Seal For Good gaskets. They seemed to get great reviews when I was researching gaskets. The Felpro's also seemed to have a good rep.
Old Mar 25, 2010 | 12:37 PM
the_merv's Avatar
Veteran: Air Force
The Copper ones that have come with the Pace Setters have worked good for me.
Old Mar 25, 2010 | 04:58 PM
95mysticta's Avatar
Well installed these new gaskets on the drivers side while i had a quick half hour to get some wrench time in and first shot these ultra seals did exactly what the name implies. They Seal! Im estatic i thought i might of had a bad batch of headers with warped flanges and first crank she sealed up perfectly. Tomorrow when im off ill get the passenger side swapped out and im off to the shop to get my catted y pipe done so i can drive it!
Mr Gasket 5903
Old Mar 25, 2010 | 09:23 PM
SoxXpupPeT's Avatar
percy's aluminum layered gaskets are by far the best gasket ive ever run. have a pair on my camaro and my impala
