SES lights on...
Old Mar 24, 2010 | 11:25 PM
SoxXpupPeT's Avatar
Default SES lights on...
I hooked up a scanner and its giving me a code "33" which states that somethings wrong with the map sensor. i had swapped it out and still its coming up with the problem. does anyone have the value of what should be coming out of the electrical pigtail going into the map sensor so i can test it ? (and yes i searched)
Old Mar 25, 2010 | 12:25 AM
MattSapp95_T/A's Avatar
Give this a try....
Typical Readings:
Sensor output voltage range is 0.5 to 4.5 volts.
Output voltages between 0.5 and 1.5 volts indicate a high vacuum (low pressure) situation, such as idle or deceleration.
Output voltages between 1.5 and 3.0 volts indicate a medium level of vacuum (pressure) such as a cruise or slight acceleration condition.
Output voltages between 3.0 and 4.5 volts indicate a low vacuum (high pressure) situation such as hard acceleration or a mechanical failure.
Any reading of 0 volts or over 4.5 volts indicates a problem.
Old Mar 25, 2010 | 07:08 AM
SoxXpupPeT's Avatar
Originally Posted by MattSapp95_T/A
Give this a try....
Typical Readings:
Thanks matt that will work out great! which wires do i do that to? the green and white one ? im assuming black is ground. i have to find my multimeter to test everything out hopefully tonight. thanks again
Old Mar 25, 2010 | 07:20 AM
MTBSully's Avatar
good info in here. Did you ckeck for vac leaks around the intake? Try spraying some Carb/choke cleaner around the intake manifold area and see if the idle comes up at all. If it does, you have a vac leak somewhere.
Old Mar 25, 2010 | 12:16 PM
No prob glad I could help..
Yes Black should be ground and the white I believe should be the source from the ECU.....
I will double check it though....
Matt
Old Mar 25, 2010 | 12:19 PM
Here you go bud should be everything you need!!
http://www.mifbody.com/DTCs/DTC%2033.jpg
http://www.mifbody.com/DTCs/DTC%2033_2.jpg
Old Mar 25, 2010 | 04:41 PM
SoxXpupPeT's Avatar
matt thanks a bunch! MTBSully ill check for vac leaks ty. i have a feeling its my harness tho. i had replaced the pigtail because it was bad... i might of messed up the ground.... but ill double check asap thanks again guys
