? Replacing roller lifters
Old Mar 27, 2010 | 01:09 PM
andysc's Avatar
Default ? Replacing roller lifters
Hi there
Got a quick question. I am doing my intake manifold gaskets as they are leaking, and with 235k on the clock thought I would replace the roller lifters, as I am sure they are getting old. My question is do they go in a certain way. I see there is a oil hole on the side of the lifter, does this go one particular way? Will it matter or can I just drop them in and as long as they line up with the dog bone be fine. Just need to know. Also I replaced the oil pump drive since I was in there. Car runs good, just trying to get to 300k so I can say I was there.
thanks
Andy Schuck
Old Mar 27, 2010 | 01:21 PM
the_merv's Avatar
Veteran: Air Force
Yea that's pretty much how they go in. I would clean them off and soak them in some Oil before putting them in, that will help lube them up.
Go get a set of LS7 Lifters..they will work well.
Old Mar 27, 2010 | 01:36 PM
monster81's Avatar
yup,,just drop them in
Old Mar 27, 2010 | 02:35 PM
andysc's Avatar
Yeah I soaked them for about a day and a half totally submerged in oil. So I feel good about that. Thanks for the input, can now put it back together.
tia
andy schuck
Old Mar 29, 2010 | 03:35 AM
suicidal racing's Avatar
dont soak them in oil...use reg asembly lube..soaking lifters will give you false reading for pre load..
Old Mar 29, 2010 | 04:00 AM
gregrob's Avatar
Umm, you want them to be pumped up when you set the valve lash...
I dont know where this dont soak them in notion came from. A VERY knowledgeable friend of mine told me the same thing.
I asked him what happened when you have a NON pumped up lifter, set vavle lash, then it gets pumped up.... It basically turns them into solid lifters lol...
Old Mar 29, 2010 | 05:45 AM
It is not necessary to pre-pump hydraulic lifters full of engine oil prior to installation and valve adjustment. It is actually UNDESIRABLE to do so as the pumped up lifters will cause the valves to open during the adjustment process, rather than positioning the valve lifter plunger in its operating position as it is supposed to do.Using reg assembly lube on the outside is a good idea or a quick coat of your oil..but you dont want them to be pumped up like above..
Old Mar 29, 2010 | 07:08 AM
shbox's Avatar
The only time a lifter might stay pumped up is at high RPM, IMHO. When you go to adjust the preload, oil is going to squish out. There should be no problem. I don't know why you would want the internals of an hydraulic lifter to be dry on startup. It would also prolong oiling to the rockers.
Old Mar 29, 2010 | 09:50 AM
the_merv's Avatar
Veteran: Air Force
I knew someone was going to say it..
Old Mar 29, 2010 | 11:58 AM
myltwon's Avatar
many people say to soak the lifters in a solvent first to clean out the jelly-like gunk that is packed in them
Old Mar 29, 2010 | 04:24 PM
a stock lifter is not a fast bleed down lifter like a rhoads lifter...what i said is the right way to do it lifters..its what comp cams recomends and others..
If your lifters are presoaked/pumped up already what do you think is going to happen when you go and put preload on them?? i can tell you 1. you will be opening your valves slightly seeing the lifter is pumped to the top already which turns it into almost a solid lifter only reason it dont is for number 2. which when you go to adj others and put load on them some will push oil out so you will have false preload on all your lifters because it takes time and the ones sitting longer will leak down and not be as pumped as your first ones..
Old Mar 29, 2010 | 06:19 PM
JAKEJR's Avatar
Maybe we have a misunderstanding as to what the terms mean; pumping/pump up/pre-pump Vs soaking/submerge them in oil
I agree, CompCams specifically says it is undesirable to "pre-pump", pumped up, pumping hydraulic lifters full of engine oil prior to installation and valve adjustment for the reason already stated by 'suicidal racing'. That information is found in both their previous and new (page 237) catalogs as well as on their website.
However, soaking is different. "Pre-soaking hydraulic lifters in a bath of engine oil is a good idea, but it is not mandatory." That's taken from the same source.
The lifter installation information I've read, contains a warning that the grease used during the assembly of the lifter must be removed before the lifter is installed. 'myltwon' is right on that one. If you consider how the grease will inhibit oil flow you'll see the reasoning for that warning.
As far as to which direction the lifter oil hole must face, I've never found anything addressing that - and I've looked. So absent any credible information saying the lifters have to be installed in a specific direction, I've concluded it doesn't matter. If it was something critical (or even important) I believe GM engineers would have included it in the Factory Service Manual.
Jake
Old Mar 29, 2010 | 07:01 PM
shbox's Avatar
Wow, I find out after 40+ years of soaking lifters in oil that it is wrong and will cause me lots of problems trying to set the valves...wait a minute...I've never had a problem setting the valves...hmmmm...I've got to pay more attention to what I am doing.
Old Mar 29, 2010 | 07:57 PM
gregrob's Avatar
:whs:
