Electrical Guru's Unite.
All of this has probably lead up to my current problem. So I jump in the car and leave the house. Everything is running normally or as normal as it gets. I run into town and stop at one of the department stores. I shut the car down and walk in. Minutes latter Im back out of the store and get in the car. I try to start it. Nothing. Radio, lights, windows, locks, everything works except for the dash lights. They don't come on at all when the key is turned on. Not even the security light comes on.
Guys I could really use your help on this one. I'm at my wits end on this. That and the car is still sitting at the store.
BTW the car is a 95 firebird formula
but this is only a suggestion and is going to take alittle time to go thru, did this just start out of no-where or did it start after something happened or was changed on the car?
So it looks like it was the ignition switch again. Since there wasn't any part stores open today I had to basically hot wire the thing to get it home.
I'm probably going to have to beef up the circuit and make my own ignition circuit since the stock switch tend to burn up on me. I believe I traced my largest load to the hvac circuit. Its was pulling over 26 amps when turned on the third to highest speed setting for the fan. Ill probably isolate that circuit and have it run off of a relay.
But thanks for the reply guys.
