What Wires to use for Long Tube Headers?
Hey What wires should I use that go Over the valve covers to the spark plugs? I'm going to be putting in my LT later today and I know people say they get burned if you go the stock way.
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
The only thing that is different about routing using the stock locations is getting a longer wire to for #5 to route along the rail and loop it back so the boot points backwards away from the primary. All other wires can even use the stock clamps as long as you use nothing larger than an 8mm wire. It is completely unnecessary to go any larger.
