1.6 nsa rockers+guide plates
I am currently running 1.6 cc magnum roller tip sa rockers,what set up should I go with nsa,guide plates,push rods,I already have stock length 7.200 hardened push rods,just want to know whats the best set up with no probs.
I'm not exactly sure what your question is here are you asking which is better or what you need? You need new rockers to change with guide plates and I'm pretty sure you need to change studs to longer ones for the guide plates.
if your motor doesn't spend a lot/most of its time in the upper RPMs then don't worry about NSA rockers. what is best is based on your needs so what are they? you have a midrange cam and stock gears so it would be money better spent somewhere else like suspension or gears.
