LT4 Knock Module
Old Sep 20, 2004 | 03:53 PM
WhiteThunderZ28's Avatar
From: Your girls house, she is on my "D", Wisconsin
I guess the LT1 KM retards the timing enough for N20 and the LT4km doesnt, thats why I keeping mine LT1 km just for that reason cause I might run N20 soon but who knows
Old Sep 20, 2004 | 04:36 PM
Nasty_T/A_GT's Avatar
I really need to pick one up sometime, Im sure it will help with my setup.
Old Sep 21, 2004 | 05:51 AM
Mike Comp T/A #57's Avatar
I use the LT4 KM with nitrous. No problems.
Old Sep 21, 2004 | 02:33 PM
357Silverado's Avatar
Does anyone know if the LT4 km would work in a 96-98 model vortec truck? I am running a LT4 hot cam in my 96 model vortec 350 and I have been getting some misfire codes which I thought might be caused by the lope from the cam.
Old Sep 21, 2004 | 02:34 PM
SAPPER's Avatar
The best route to take is be safe not sorry. Since the LT1's don't have DIS, unless you installed it, Run a igniton box, (MSD Digtal 6), that has a built in retard and a separate window switch for the N2O activation. Now, I have a DIS on my LS1, it sucks not to be able to control the retard. But I don't have the juice on it....YET.
Better to spend $400 now than $4000 later. And the Imps D6 is awesome and I love it. Dial in what you want and Voila', it's ready. rev limiter, retard when the juice is activated at 3k-6200 and pulls 4* of timing.
Just some friendly advice.
Old Mar 17, 2010 | 02:17 PM
scarfache's Avatar
Do the 1993's with the old ECM have a knock module? If so, will the LT4 one work? I have the LT4 Hot Cam Kit but I don't think anything PC wise was touched from the prev owner.
Old Mar 17, 2010 | 03:35 PM
mpcv2000's Avatar
Interesting subject.
So if I understand clearly you can swap the module behind a regular LT1 PCM ( OBDI if that matter ) for a LT4 module and it can help ?
I have a hot cam from GM with some 1.6RR and the valvetrain is pretty noisy so I may be getting some false knock from my setup ?
Do you need to have a new tune on the car or just swap it and go ?
I thought you guys were talking about the knock sensor on the block itself.
Old Mar 17, 2010 | 03:47 PM
djjab57's Avatar
If you get a tune you dont really need one as it can be corrected with the tune
Old Mar 17, 2010 | 04:39 PM
z_speedfreak's Avatar
x2 both of you guys should get a tune since your not running the stock cam anyways, besides that GM stopped making LT4 KM so you have to do some searching for 1, last I knew the ws6 store has some left
Old Mar 17, 2010 | 05:28 PM
spudnick3119's Avatar
That's not necessarily true. The tune will only lower the knock values stored by the PCM (max knock at rpms, %knock removed, %knock added, etc...), not change what the KM is listening for. The LT4 KM looks for different kinds of "knock" (due to the LT4's rockers), nothing is changed in the PCM by swapping out knock modules.
The knock module will also only benefit you if you are getting knock. If you are not getting any knock and the pcm is not pulling timing, you will see a 0.0% power increase. The only way to determine if you are getting knock is to hook up a scanner (Datamaster, Freescan, etc...) and confirm.
Old Mar 17, 2010 | 05:50 PM
kaganader's Avatar
plus the LT4 knock sensor is discontinued
Old Mar 17, 2010 | 05:51 PM
  #32
djjab57's Avatar
I didnt say it was the smartest thing to do but a lot of people just tune it completely out
Old Mar 17, 2010 | 05:52 PM
  #33
djjab57's Avatar
This i know as i am the one who started the thread
Old Mar 17, 2010 | 05:53 PM
  #34
kaganader's Avatar
haha just thought ill share the knowledge for whoever brought this back from the dead
Old Mar 17, 2010 | 05:57 PM
  #35
djjab57's Avatar
LOL i bumped my old thread
Old Mar 17, 2010 | 06:06 PM
  #36
mpcv2000's Avatar
In my case I do have a tune , the LT1 is in a 89 Turbo II Mazda.
I realized that today.
I just noticed the date is was started.
Still good information tho.
Old Apr 26, 2010 | 09:28 PM
  #37
coop875's Avatar
goin for 110 on ws6 store
Old Apr 26, 2010 | 09:45 PM
  #38
1961ba427's Avatar
Yes!! Very good information. I opened up the PCM on my 97 yesterday to install LT4 km I bought about 3 years ago (to go in a 96 Formula I bought not running and STILL isn't running). Well I got the cover off and there was already one installed. I was thinking about selling the new one and just getting one later when I finally (hopefully) get the 96 running, but if it's discontinued I will hold on to it. Wish I had bought a pile of them.
Old Apr 26, 2010 | 10:08 PM
  #39
1961ba427's Avatar
Summit says they have them for $75.95 and it can ship tomorrow. I bet they won't last long.
Old Apr 26, 2010 | 11:02 PM
  #40
shbox's Avatar
The LT4 KM is not discontinued. It was on national back order for a little while.
