crank reluctor?
Old Mar 31, 2010 | 12:21 AM
kalebm22's Avatar
Restricted User
Default crank reluctor?
idk if thats what it is called but it is the ring that goess on the crank snout between the crank sproket and the timing cover. this piece somehow spun on the key of the crank and tore it up a little. does anyone know where i can get a new one?
Old Mar 31, 2010 | 03:15 AM
letsrun97z's Avatar
You can have it tuned out if you didn't already know
Old Mar 31, 2010 | 06:59 AM
shbox's Avatar
GM PART # 10190917 any dealer can get you one.
Old Mar 31, 2010 | 09:45 AM
Corey @ Clayton Racing's Avatar
Im sure I have a few out of motors around here if you need one, they wont be new though.
Old Mar 31, 2010 | 11:25 AM
kalebm22's Avatar
Restricted User
i didnt know u could have them tuned out, does it cause any problems? are there any benifits to it? do i tell them to tune out the crank sensor?
Old Mar 31, 2010 | 11:26 AM
RamAir95TA's Avatar
It only is used for detecting misfires and setting the SES light - nothing more.
Just have it tuned out.
Old Mar 31, 2010 | 11:28 AM
kalebm22's Avatar
Restricted User
thanks corey i may hit you up on that if its a problem to tune it out. i also wanted to ask you what the max rpm is for the rotating assembly you guys sent me. it was the scat kit with the arp 2000 rod bolt upgrade with the cp flat tops/chromoly rings.
Old Mar 31, 2010 | 08:45 PM
kalebm22's Avatar
Restricted User
ok thanks for helpin me out, i didnt think it was that useful. im guessing this may have been causing my car to shut off sometimes under hard throttle. do u think that could cause it?
Old Mar 31, 2010 | 08:52 PM
RamAir95TA's Avatar
Nah...it doesn't have anything to do with how the car runs. It's only used for detecting misfires.
Old Mar 31, 2010 | 08:55 PM
kalebm22's Avatar
Restricted User
well shoot, i guess the search continues. i really apreciate the help though.
