Does anybody know what connection this is?
Old Mar 30, 2010 | 10:28 AM
Z28Power's Avatar
Default Does anybody know what connection this is?
Well when i bought the car the seller said he didn't remember what kind of chip it was and lost the packaging and im wondering what this is because i need to tune the car and pcmforless told me if its a jet chip i can only have one or the other.
The car is a 1993 z28 Camaro 6 speed LT1 350, various mods are lt4 hotcam kit with comp cam rockers rollers 1.6 ratio, underdrive pulley, edelbrock shortys, chrome vaulve covers as well as caps and dipstick, and whatever chip this is supposed to be lol.
also theres a wierd toggle switch behind the shifter console -
does anyone know what type of chip or connection this is?
Old Mar 30, 2010 | 10:32 AM
z_speedfreak's Avatar
thats your OBD port
Old Mar 30, 2010 | 10:37 AM
Z28Power's Avatar
Originally Posted by z_speedfreak
thats your OBD port
it doesnt look stock in the 2nd pic u can see some black tape around the wires
heres a pic of another connector off the the right side -
Old Mar 30, 2010 | 11:32 AM
O yeah that^^^ is your OBD port. can't really tell what I'm looking at in the 1st pics now..what does it look like from the bottom?
Old Mar 30, 2010 | 11:36 AM
old93camaro's Avatar
if you have a chip it will be in the PCM not the port the chip will be under the hood in the left upper corner in that black box or case
Old Mar 30, 2010 | 11:37 AM
illusions's Avatar
if your getting a pcmforless tune then remove the jet chip because it will not be needed. trace the wires from the connector and see if it plugs into the pcm. the other connector on the gas pedal side is the pcm obd connector. iirc
Old Mar 30, 2010 | 04:47 PM
Z28Power's Avatar
I'm not sure if it's a jet chip or not it doesn't look stock and the 2 nd picc shows what it looks like from the bottom the wires go into the steering column and are taped up with black tape it's on he left side of the steering wheel
Old Mar 30, 2010 | 10:20 PM
Z28Power's Avatar
does anyone have an idea? ive tried new era performance they wont touch ne thing lower than an ls1 and all the other tuner shops have no idea what it is. Called pcmforless today and they have no idea either...
Old Mar 30, 2010 | 10:31 PM
jaycenk's Avatar
Pro lock or something like that? My 97 has a pro lock which is a simple theft deterant. Yours looks like the key is not in though. Are the wires conected to it or not? It should have the ignition wires conected to it.
Old Mar 30, 2010 | 10:34 PM
Z28Power's Avatar
well in the 2nd pic there are some red wires taped up into the steering column
Old Mar 30, 2010 | 10:40 PM
Z28Power's Avatar
well i looked it up the picture looks different than what i have also if it was prolock i wouldnt be able to start the car without the key -
Z28Power's Avatar
http://www.aboutsecurityconcepts.com...ode=Loctronics
Old Mar 31, 2010 | 02:23 PM
Z28Power's Avatar
Does anyone have an idea to what this onnection is?
Old Mar 31, 2010 | 02:56 PM
djjab57's Avatar
If you want some help your going to have to do a little work first, Pull off that bottom cover and see where the wiring from it goes. Take some pics and post them up. It could be some kind of homemade crap, seeing where it goes will help
Old Mar 31, 2010 | 03:45 PM
shbox's Avatar
...and don't take pics that look like you were driving the car when you took them, LOL!
Old Mar 31, 2010 | 05:49 PM
garage_queen's Avatar
My car had that when I bought it. It is a security key/chip. Not sure how you're running without the key/chip not in the slot though. Maybe it's been bypassed or disconnected or possibly the little toggle switch is a bypass. It's not computer related.
Old Mar 31, 2010 | 06:09 PM
jaycenk's Avatar
It may not be a prolock but there where other variations back then. Most did not know how complicated the security system already was. Alot of cars had bad keys through the years where the risistor wears down and one thing guys did was to take the prolock or similar product out of the loop. So you could be running with out it if it is not hooked up. What brand does not matter. They where dealer and aftermarket addons. Not stock. It works like a kill switch is all. You can disconect it and take it out of the loop in a matter of minutes. Take some good quality pics and maybe someone will know what brand it is. I can't imagine it a brake controller lol.
Old Mar 31, 2010 | 09:16 PM
Z28Power's Avatar
well there isnt a brand on it its just a black box that goes into the stearing column and as u can see in the pic the piece looks like someone installed it themselves looks broken.
