fuel pressure ?
Old Mar 31, 2010 | 03:46 PM
andrew ws6's Avatar
Default fuel pressure ?
I put my walbro pump in and now it hardly has any breakup on top end but stalls on idle like it is running rich, checked my fuel pressure with hose attached it is right at 40 with the hose off it is right at 48, is this enough to throw off the injectors?
Old Mar 31, 2010 | 03:47 PM
RamAir95TA's Avatar
Your static fuel pressure is fine. Does it hold with the key on, engine off?
Old Mar 31, 2010 | 04:01 PM
andrew ws6's Avatar
just went out and check after 15 mins it is still at 42
Old Mar 31, 2010 | 04:16 PM
RamAir95TA's Avatar
Sounds like your fuel pressure is just fine. Could be plugs, wires, vacuum leak, IAC, TPS, tune, etc.
