LS1 head conversion
Old Apr 1, 2010 | 05:33 PM
86formula's Avatar
Originally Posted by FASTFATBOY
**face palm** Ls heads on a LT
If he is gonna run 12.5 to 1 he needs MUCH more cam to run pumpgas.
With a 230 ish cam he needs to stay around 11.5 to 1
sorry shouldve worded that different
Old Apr 1, 2010 | 05:37 PM
1badzee's Avatar
Originally Posted by white ghost
so say for example here is my wish list, critique it please.
Forged internals@ 10.2-5:1 comp.
ported AI heads(not sure on dimensions)
Decent ground cam(22x/23x:.600?)
Full exhaust
Port and Polished intake
Fuel system upgrades
3600 Yank or DD stall
How does that look so far? please add or change at will.
Sounds good so far. You ford guys love that low compression on built motors (or at least that's what the guys around here do). Aim upward of 11:1 to meet your goals. Have Lloyd Elliot or Advanced Induction port-match your intake manifold to the heads.
Old Apr 1, 2010 | 05:55 PM
white ghost's Avatar
Lol. yeah that's the creed of 4v ford guys, low compression and big boost. lol. that is exactly why I'm asking for all of you guys input and I really appreciate it.
Old Apr 1, 2010 | 10:00 PM
1961ba427's Avatar
They won't fit on an LT1, but I hear that you can run them on a 351 Windsor fairly easily. Like someone else said....IDK why you'd want to do that instead of just building an LS1 to begin with, but I hear that it's done.
Old Apr 1, 2010 | 11:41 PM
gregrob's Avatar
10.4:1 is stock just so you know. AI or Lloyd can get you mid / bottom 11s on a 355 depending on the setup (suspension, tire, trans, gear).
I would do a 11.7ish compression, healthy cam, and AI 200cc heads / intake. Full bolt ons.
Old Apr 2, 2010 | 12:35 AM
93Z2871805's Avatar
Veteran: Air Force
Can be done with a SBC...
http://www.superchevy.com/technical/...ine/index.html
Old Apr 2, 2010 | 01:21 AM
1961ba427's Avatar
Originally Posted by 93Z2871805
That is with a special casting World Products block. From what I've been told they will fit on a production 351 Windsor motor with only minor machining. I haven't seen it done personally though.
Old Apr 2, 2010 | 02:26 PM
LT1SS's Avatar
Just as the title says. Is it possible to convert a pair of LS1 heads onto an LT1? The reason I ask is I can get my hands on a set of stock '02 LS1 heads for practically nothing and it would be awesome to be able use these heads especially considering the heads are the weaker link with the LT1 engine. Thanks in advance.
actually i saw something on tv a while ago about that... there is a company, forgot their name, but they make a kit to bolt ls heads on a gen 1 block. not sure about a gen 2. the kit works like wheel spacers. bolt the plates to the block then the heads to the plates. have to get a custom intake though. not sure exactly how it works but i know its out there. but like everyone else said the mod would be pretty much pointless
