Guys I need injector sizing.
Old Apr 1, 2010 | 08:00 PM
SPRAYED Z's Avatar
Default Guys I need injector sizing.
Hi guys I will be running a 383 with LE2 heads and ported intake with a 238/242 cam. It will have about 12.5 c.r and will be backed by a 3.73 gear with a 4000 stall. Lots of nitrous will be used from a wet kit and I have a 255 pump already installed. I was thinking about using 36# injectors but what would really be needed for this combo to work effectively with and w/o nitrous?
thanks, TOM
Old Apr 1, 2010 | 08:39 PM
robsquikz28's Avatar
42s would work fine, hell you might be able to even use 36s with a good tune. How much do you plan on spraying anyway?
Old Apr 1, 2010 | 09:46 PM
FASTFATBOY's Avatar
42 pounders
Need a standalone fuel system? I got one see my sig.
Old Apr 1, 2010 | 09:57 PM
86formula's Avatar
ill be using 42s with slightly more exhaust duration. im using a plate kit with a stand alone for a 250 shot
Old Apr 2, 2010 | 08:05 AM
RamAir95TA's Avatar
42#. I have a similar setup and that's what I'm using.
