timing cover
Old Apr 3, 2010 | 02:43 PM
Jcl_96TA's Avatar
Default timing cover
Does the oil pan gasket have to be replaced with the timing cover gasket?
Old Apr 3, 2010 | 02:47 PM
collier341's Avatar
I believe if you were careful pulling the timing cover and put a dab of RTV on the corners when re-installing you should be good.
Old Apr 3, 2010 | 02:49 PM
Jcl_96TA's Avatar
god i hope so! i
Old Apr 3, 2010 | 03:28 PM
SS RRR's Avatar
Village Troll
Even if the oil pan gasket tears apart from the two corners you can still use sealant to avoid it from leaking. Because the gasket starts to harden over time there's usually no way to peel it off the timing cover in tact.
Old Apr 3, 2010 | 03:44 PM
ls1adamls1's Avatar
mine tore very slightly, i just put some copper seal rtv to make sure it dont leak
