carb swap thread
Old Apr 10, 2010 | 01:14 PM
suicidal racing's Avatar
im not sure if the stock lt1 throttle cable will work or not.but what i listed above will has the return an such just no cabel..but i just looked at it more and it does not have a kick down cable deal..ive not yet done this swap but just been reading into it and had a parts list made and figured i would list whats needed seeing it was bits and pieces of info scatterd around..i just now did a better write up and linked the thread to above.
Old Apr 10, 2010 | 04:07 PM
ADM's Avatar
ADM
I added the kickdown bracket that is in the suggested parts for Chevy. For the cables and such, I can ask around locally, got some experienced guys around here.
Bro, you have helped me alot here. I wish I could return the favour some how.
Just another question, will my dash gauges still work or will I need replacements?
Old Apr 10, 2010 | 04:50 PM
seeing your pc runs all the stuff i believe you will need replacements.. or you may be able to wire them up with out the pc..im not sure if the electronic signal gos straight to the gauges or to the pc and then the gauges..im sure a quick search would lead you to you answer..
im going to run all mech. gauges for my car.
and its no problem bro..**** thats what these sites are here for..
Old Apr 10, 2010 | 04:53 PM
ADM's Avatar
ADM
I already have an aftermarket tach, I would need the oil pressure, water temp and volts only.
I tried many times before, most of the threads were ignored if not all. Can't wait to pull the trigger on this conversion.
Old Apr 10, 2010 | 04:58 PM
yep..that and then fuel level..
heres how my old 4th gen was..i had them 3 gauges in the center and then my tack to the side.
