carb swap thread
Old Apr 6, 2010 | 12:51 PM
06hemi's Avatar
Default carb swap thread
im starting this because im swapping to a carb on my 93 z28 and am wondering what works im goin with a gen 1 intake so there will be modifing but everyone goes with a rear mounted distribitor is this something that i have to do or can the opti work with it some how
Old Apr 6, 2010 | 12:55 PM
z28racerlt1's Avatar
Depending on what you are looking to do I went with a Vic Jr. intake and a crank trigger dist. I also ran a crank trigger. I cut the cowl back to the firewall. Actually about an inch away from the firewall. I could pull the dist out of the car without any problem. The normal dist also makes routing plug wires a little easier.
To answer your question I am not sure how to make the opti still work.
Ken
Old Apr 6, 2010 | 02:38 PM
rkinney's Avatar
If you were really wanting to keep the opti, why not run it off of the factory computer. You would need to keep the map sensor, but I don't see why it wouldn't work. If you have a way to tune it, you would still have full control over your ignition map.
Old Apr 6, 2010 | 03:16 PM
suicidal racing's Avatar
i dont see why you would want to run an opti with a carb..just use a hei distributer or a msd 6al box setup..plus when doing this you can ditch the ecu **** and all the other b.s wires.
Old Apr 6, 2010 | 04:25 PM
rkinney's Avatar
^^^I would have to agree.
Old Apr 6, 2010 | 06:25 PM
slownova73's Avatar
go with a distributor, throw the opti in the trash and be done with it.
Old Apr 6, 2010 | 08:35 PM
86formula's Avatar
or go with a Vic EFI manifold and use the computer to tune it, im going with a 4 barrel TB and staying fuel injected with mine and keeping my opti
Old Apr 6, 2010 | 09:11 PM
06hemi's Avatar
either goin carb or maybe some type of elbow and a big single throttle body withe the dual plane lt1 intake
Old Apr 7, 2010 | 09:17 AM
foggedz's Avatar
You would lose a good amount of HP if you put a dual plane intake on the car.
Old Apr 7, 2010 | 10:01 AM
^wrong a dual plane lt1 carb intake makes better mid to upper power then our stock efi intakes.stock efi intakes will make better low end.tom cowle who has the bolt on record right now did a carb setup and stock setup and told me what i just said after hours on end of dynoing
Old Apr 7, 2010 | 10:07 AM
flaminbird's Avatar
I'm scratching my head here. You're wanting to go with something that could potentially elemenate one the weakest links on the LT1 (opti) and you want to keep it? Man, I'm with the other guys, yank the opti, go HEI. Do me a favor though, from someone that has fought numerous opti issues, when you take it off, don't just throw it in the trash.... douse it in lighter fluid, light it on fire. Once the fire goes out, either you, or someone else, I don't care, but drive a bulldozer or steam roller over it. After that, tie it to your back bumper and drag it around a while, and then, and only then, throw it in the trash.
Old Apr 7, 2010 | 10:33 AM
I agree with this. I went from a ported stock intake to a carb and Dual Plane and picked up one tenth in ET. I gained over 2 MPH.
Ken
Old Apr 7, 2010 | 11:08 PM
06hemi's Avatar
awesome i was told they like the dual plane but if i go with an hei what do i need to do with the computer just send my chip back to pcmforless and have them retune it or what and also ive been told of some type of angled spacer to run a gen 1 intake the only reason i ask is cause i have on and its a 93 car with a 700r4 so i dont think linkage will be a issue
Old Apr 9, 2010 | 04:36 AM
my thread i made for this now
https://ls1tech.com/forums/lt1-lt4-m...l#post13167404
Old Apr 9, 2010 | 06:02 AM
somlt1's Avatar
you can do a 4l60 with out the stock computer but you would have to buy something like this control unit from tci -http://www.summitracing.com/parts/TCI-377500/
Old Apr 9, 2010 | 06:23 AM
^thanks added it to the list..im going to let this sit for a day and make it,its own thread to try and get it stickyed
Old Apr 10, 2010 | 07:19 AM
ADM's Avatar
ADM
suicidal racing, thanks so much bro for the detailed information. You helped answer lots of questions and I managed to chose parts for my conversion finally.
I do have some questions though (sorry if it seems like I am highjacking the thread)
For my fuel return line, how big does it need to be?
This is a list of my parts :-
http://www.summitracing.com/parts/AEI-13301/ fuel pressure regulator
(I intend to keep my stock fuel pump)
http://www.summitracing.com/parts/AEI-15632/ a gauge to monitor pressure
http://www.summitracing.com/parts/AER-FCP0102/ fuel lines to feed the carb
http://www.summitracing.com/parts/HLY-0-80508S/ 750cfm carb (is this too much for a cc503 with slightly ported heads and full bolt-ons?)
http://www.summitracing.com/parts/HLY-20-45/ kick down bracket
http://www.summitracing.com/parts/MSD-3565/ wires
http://www.summitracing.com/parts/MSD-8203/ blaster 2 coil with balast resistor
http://www.summitracing.com/parts/MSD-8360/ ready to run distributor, magnetic pick up, vacuum advance
http://www.summitracing.com/parts/NAL-12367600/ timing cover block plate
http://www.summitracing.com/parts/NAL-24502592/ intake manifold
http://www.summitracing.com/parts/PFS-80030/ damper with timing marks
Also, will I need a hold down clamp? If I am missing anything, let me know please.
Old Apr 10, 2010 | 11:10 AM
you will need a distributer hold down clamp yes..
as for your return line seeing you going to run your stock pump your feed line will be a-6 probley and i would run a -8 for a return seeing you pump is designed for high pressure..
if you want eletronic choke then get that carb if not then grab this one..these will be enough..look around on boards you belong to also because you can get a used 750cfm double pumper 4150 for 100-200$ and then a rebuild kit is only 50$
http://www.summitracing.com/parts/HLY-0-3310C/
oh yeah you will also need carb linkage and a plate/holder
http://www.summitracing.com/parts/HLY-20-88/
Old Apr 10, 2010 | 11:26 AM
adm you need a gauge port on them lines to use that gauge.
Old Apr 10, 2010 | 11:56 AM
ADM's Avatar
ADM
Will i need any cable installation kits with levers, springs and retainers?
I will be installing an adapter to tap off the end of the dual feed line and read pressure there. That is why I chose the Aeromotive instead of the Summit which is just a 90 degree bend.
