Need some help with Spark Plug wire install
Old Apr 6, 2010 | 10:34 PM
GoFastKid's Avatar
Default Need some help with Spark Plug wire install
Does anyone have a link to a break down/step by step process to change out the spark plug wires on a 94 LT1? Never done it and I am attempting it tomorrow.
Thanks!
Old Apr 6, 2010 | 10:46 PM
MattSapp95_T/A's Avatar
I don't know of any step by step but it isn't too bad....
Driver side is really easy just pull off one spark plug wire at a time and put the same length one back on....Make sure to use anti seize on your plugs and start them by hand so you don't cross thread them...
Passenger side I do the rear 2 from under the car and drop the starter...its just easier.....
I do the front passenger side 1 from under the car too....Cylinder 4 i do from the top....
Zip ties are your friend...make sure the wires are not touching the headers but I am sure you already know that....
Matt
Old Apr 6, 2010 | 11:09 PM
I8ASaleen's Avatar
Just use some common sense in running them - keep away from moving parts and things that are exceptionally hot, should be good to go. If you bought a set that is a specific length then you are stuck with only a few routing options.
Old Apr 6, 2010 | 11:26 PM
Torque Fiend's Avatar
My over-the-valve-cover length wires were nice to route under my Long Tubes.
No problems/burning/arcing.
