Oil cooler help needed
Old Apr 7, 2010 | 11:44 PM
Nads06111's Avatar
Default Oil cooler help needed
I was putting my car back together tonight and can’t seem to find the bolt for the oil cooler. Where can I get one? Also which washer(s) do I use? There are 2 types that came in the package Napa pn7302922
Old Apr 8, 2010 | 03:43 PM
Nads06111's Avatar
Anyone?
Old Apr 8, 2010 | 04:05 PM
shbox's Avatar
Describe "the bolt". Might help.
Old Apr 8, 2010 | 04:48 PM
fex77k's Avatar
I hope its not the one the oil filter screws onto, I didn't think you could take it off. There are two bolts for the bypass plate and at least another bolt that holds the coolant lines but that's all that is there.
Old Apr 8, 2010 | 11:44 PM
Nads06111's Avatar
sorry. the bolt i need is the bolt that fastens the coolant tubes to the oil cooler.
just need to know the size or if i can get a replacement because i cant find it
Old Apr 8, 2010 | 11:50 PM
airfix's Avatar
If you cant find it or find a replacement, I have one you can have. I just took my oil cooler off last week. Easiest thing to do would be to delete it.
Old Apr 9, 2010 | 07:36 AM
shbox's Avatar
"The bolt" is M10 x 1.5 x 30.
Old Apr 9, 2010 | 09:07 PM
Nads06111's Avatar
perfect. thanks
