lt1 idle problem need advise - fresh build
what are you talking about when you say you drilled a hole where the iac is. I am haveing the same problem with a buddys car and he has already drilled holes in blades and the iac count is still 160 maxed out and it wont idle.
i didnt drill through the blades at all.... there is a little hole on the bottom of the throttle body if your looking at it frontwards and looking at the blades... on the stock TB there is a hole drilled straight through in there to allow some airflow... on the aftermarket peices there is no hole... so i drilled that hole in there... just start small and work your way up untill your counts come down... get what im saying?
http://members.***.net/chipsbyal/page/idle/index.html
http://www.hashmarks.com/techtips/throttle_body_mod.htm
just start small, you will probably work you way up to or very close to 1/8" but i would start at least 5 steps below that. it helps if you have a scanner and can check after each drill pass. make sure you clean those shavings! check the iac count in closed loop too.
for those who cracked the blades, i would ensure you are seeing correct voltage on the tps signal wire with the blades fully open. would suck if you aren't getting full throttle!
