'94 Firebird Wiring Question
What else would i have to switch, just the computer or what?
Any help would be great, thank you.
Get some documentation so you can see where things are between a V6 and V8 from 94. Look for things like location of fuel lines, cannister, etc. Some will be the same, a few things will be different. Emissions features you want to keep vs. delete will be a factor. Exhaust will have to go completely, obviously. Three are a few V6-V8 swap threads so have a look around...
http://www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm
i will not have to change my wiring? but i will need to change the gauge cluster, and it should be fine?
The engine harness will come out when you remove the pass. side kick panel (after you pull the old PCM, you'll see where the 2 big chunks of it go in through the firewall).
You might want to change the speedo head to a 150MPH while you're at it. All other interior accessories, etc- their wiring will not need to change.
Get your driveline ready to accept the engine and trans and you'll be shittin' in high cotton...
motor mounts- find some blown out cores on Ebay, etc. I think Trans Am creations (your site above) is an Ebay seller for old mounts with trashed inserts. I bought a pair to do my mounts with Prothane inserts so I could do a quick swap instead of pulling them and then doing the inserts with the mounts off the car to save lift time. Like $25.00 for the clamshells. If I had done it yet, I'd let you have my old ones (still good, but def. would do urethane MMs.
At least have the bearings replaced while it is out. LT1's from F-bodies and B-bodies were not usually run easy.
