need help on ring and pinon investment
Old Apr 11, 2010 | 02:10 PM
camaro luster's Avatar
Default need help on ring and pinon investment
which gears would be better for all around on the street and on a 8th and 1/4 mile? and what mph does each gear get up to at red line?
Old Apr 11, 2010 | 02:13 PM
whytryz28's Avatar
Need more info, what transmission and tire size will you be running?
But the general rule of thumb is, A4 = 3.73 and M6 = 4.10
Old Apr 11, 2010 | 02:31 PM
i have a t56 with 275/35 on 18s
Old Apr 11, 2010 | 02:39 PM
bigj2717's Avatar
Whats done to your car. Since you have a m6 4.10's are a good size to go with
Old Apr 11, 2010 | 02:57 PM
gregrob's Avatar
3.90s.....
Stronger than 4:10 a tad longer in each gear, better mileage, etc...
I've ran both and will never go back to 410 or lower. It would be different of you had a cam and setup that needed the rpms in the 1/4. Say a big solid roller, etc.
I'm still having to wind it over 6300 going through the traps so I def don't feel you need lower than 3.90 in a mild street car.
JMO
just cold air and mass air flow
Old Apr 11, 2010 | 03:07 PM
Originally Posted by gregrob
3.90s.....
JMO
where is a good place to get 3.90s?
Old Apr 11, 2010 | 08:05 PM
gregrob's Avatar
Anyone who sells Motive.
