No Fuel (I think)
Old Apr 11, 2010 | 08:28 PM
95BlkBird's Avatar
Default No Fuel (I think)
So I tried to start the car today after replaceing intake gasket yesterday and it wont start. Now I took the intake off a couple weeks ago to clean paint ect....so the fuel rails have been completely emptied and the fuel lines were off for the whole time. After finishing up loose ends I tried to start it and nothing. It started for a second and ran ROUGH then died. Now wont start at all. It doesn't seem to be getting fuel. Is there something I'm missing? Do I need to do anything special to get fuel back into the fuel rails? Thanks in advance.
Old Apr 11, 2010 | 08:30 PM
SoxXpupPeT's Avatar
did you bleed the fuel rail ? if you have everything hooked up right, you should just have to turn the ignition on and off afew times then bleed the shreader valve on the back of the rail.. make sure you have all the injector plugs in the right spot aswell.
Old Apr 11, 2010 | 08:35 PM
95BlkBird's Avatar
Hmmm Nope didn't bleed them. How would I go about doing that. Oh and I got the pics Chris and looks good to me.
Old Apr 11, 2010 | 10:16 PM
SoxXpupPeT's Avatar
im glad they do john. as for bleeding the fuel rail. turn the ignition on and off afew times. then leave it on and press the small pin in the schrader valve on the back of the fuel rail
http://shbox.com/1/fp_reg.jpg
air should come out if its air bound. bleed it until nothing but fuel comes out
Old Apr 11, 2010 | 10:36 PM
95BlkBird's Avatar
Ok I did it about 4 times and everytime air would come out then eventually nothing. Do I just keep repeating this over and over till no air all gas?
Old Apr 11, 2010 | 10:39 PM
SoxXpupPeT's Avatar
yes. make sure your pump is working. or that you hav efuel in the tank. you should hear the fuel pump prime.
Old Apr 11, 2010 | 10:44 PM
95BlkBird's Avatar
yea I hear it priming. Guess I will keep trying it. Thanks for the info Chris
Old Apr 11, 2010 | 10:50 PM
BlueRamAir's Avatar
I had this issue once. It took like 15-20 times till it was good.
Old Apr 11, 2010 | 11:10 PM
SoxXpupPeT's Avatar
NP john! i hope it works out for you.i luckily havent had that problem with my camaro. but with my old buick i did. it kept stalling on me. once i bleed the fuel rail it ran perfectly fine
Old Apr 12, 2010 | 09:09 PM
95BlkBird's Avatar
Absolutely freaking rediculous. So I KNOW there was fuel in the tank before I parked it. Obviously it evaporates fairly quick. Of coarse the gauge read empty so 5 gallons of gas later.... Starts lol. I realized this after bleeding the fuel lines 20 times! There is smoke rolling from the engine bay and I'm going to chalk this up to all the cleaning and painting I did (Ihope anyway) since it doesn't smell like oil. This is one for stupid Noob mistakes.
CHECK GAS BEFORE YOU START TO TEAR DOWN THE FUEL INJECTION AGAIN! :/
Old Apr 12, 2010 | 09:22 PM
SoxXpupPeT's Avatar
hahaha awwww john that sucks! but atleast you found the problem! how is it running now ?
Old Apr 12, 2010 | 09:35 PM
95BlkBird's Avatar
Runs good. #7 plug wire is arching so it's got a bit of a miss but thats on the to-do list. This smoke is scary me though. I let it run for about 15-20 mins and its still coming every now and then.
Old Apr 12, 2010 | 09:40 PM
SoxXpupPeT's Avatar
what does it look and smell like ? is it antifreeze or oil ?
Old Apr 12, 2010 | 09:47 PM
95BlkBird's Avatar
It's coming from the back. nothing is dripping that I see. Doesn't really smell like either. Will hafta dig around tomorrow when it light again I guess
Old Apr 12, 2010 | 10:13 PM
SoxXpupPeT's Avatar
could just be condensation burn off... did you check your spark plugs ?
