Need help determining where parts go
Hello all. I started this overhaul project on my 96 Z28 about 3 years ago. Good news is that it's almost back together now. The bad news is, I have some parts that I have no idea where they go and can't find much looking through pictures online or in the haynes manual. I have included an image below to show what the 3 parts are. Thanks in advanced!
THe thing on the right goes to two vacuum lines on the passenger side. It slides on a metal tab in between the valve cover and the Intake right behind the alternator. The other black thing with all the hoses coming off of it connects to the first black thing via the long skinny vacuum tube witch is routed under the throttle body and attaches to a tab above the air pump on the drivers side. The metal bracket i am not sure of.
The piece on the left is part of the AIR pump system. The thicker hose mounts to the AIR pump.
The piece in the middle is a small support for the A/C compressor that bolts to the motor mount/block (IIRC).
The piece on the right is the EVAP purge solenoid which mounts to the passenger side of the intake manifold.
Here is a pic of the one thing on the right what it looks like on my car. The other is a pick of the thing on the left but i am not sure if it is the same it looks different on my car. Maybe cause mine is a 96idk
