difference in early and late dipsticks
Old Apr 14, 2010 | 03:40 PM
ElkySS's Avatar
Default difference in early and late dipsticks
how much of one is there? when i put my lt4 in my 94 dipstick tube didnt want to go in all the way so i cut about an inch off the end. im really just curious why my motor with a stock oil pan took 6 quarts to read full. should i buy a 95-up tube or leave it alone?
Old Apr 14, 2010 | 03:51 PM
RamAir95TA's Avatar
The dipstick tubes and indicators are the same for all year f-bodies.
Old Apr 14, 2010 | 04:15 PM
ElkySS's Avatar
u sure? i could have sworn i saw there wer 2 different part numbers somewhere.
Old Apr 14, 2010 | 04:21 PM
RamAir95TA's Avatar
I just checked my parts manual, and they are both the same part number.
Old Apr 14, 2010 | 04:35 PM
ElkySS's Avatar
that confuses me even farther. was there a different one for the vette? i dont get it. we had to cut the bottom inch off of the tube to get it to go in. the stick doesnt hit anything and goes in normally. anyone else have to do this? maybe it was hitting the crank since its a stroker crank.
Old Apr 14, 2010 | 08:06 PM
RamAir95TA's Avatar
The stroker crank issue was likely your problem. I had to cut my tube about an inch shorter, too.
Old Apr 14, 2010 | 08:27 PM
96capricemgr's Avatar
4-bolt main caps get in the way of the dipstick.
Old Apr 14, 2010 | 08:42 PM
fergymoto's Avatar
^What Dwayne said. Also, there are two different dipsticks. the 93-94 and possibly the 95 (not sure) had a different dip stick. It interchanges are far as I know (probably why there is now only one part number) but there were FOR SURE two different sticks. The tube on the other hand, not sure.
Old Apr 14, 2010 | 10:19 PM
robsquikz28's Avatar
Yep my 94 is different from both of my 96s, but only the stick!!! NOT the tube.
Old Apr 14, 2010 | 11:48 PM
ElkySS's Avatar
oh ok. now that we have that cleared up, anyone wanna take a guess how it took 6 quarts and the dipstick reads full (not over full)?
Old Apr 14, 2010 | 11:56 PM
kaganader's Avatar
Mine usually takes between 5.5-6 quarts of oil to read full. I just did the oil change today and I had to put in 5.75 for it to read full.
mines a 96 camaro.
