Recommendations on Headers for my LT1 Daily Driver?
The car is all stock with 84k's on the clock. Its my daily driver, and im researching and saving $$ for my mods and upgrades.
The current exhaust: stock, cut off past the cat. (way loud and rattles the entire interior)
If im going to save the money for new exhaust, i might aswell save for the good stuff and upgrade it from the headers on back.
But if you insist on buying the "best" Id go with Kooks headers, ORY mated to a GMMG with CME would be it...Just what I think.
You could go with pacesettter LT's that are coated and should last 3-5yrs down in FL. They run 450ish for the set, with gaskets and bolts. 600ish is with the y pipe. Grab those and either SLP, Hooker, Magnaflow catback for 350 and you should come in around 1k for parts.
Another option would be buy the coated LT's and do a custom true dual setup. Going over the axle can get costly but dumping them before it should be very cheap and provide good HP gains. If you put up with what you have now this should be nothing as far as noise, drone, rattles, etc. dumps-100-250. over axle 350-700.
While your at it, do the sparks plugs no questions asked. If money allows the wires and motor mounts, o2 sensors, fuel filter should be done.
If you stay on top of the FS section you should be able to find some pretty good deals. Thats what i did, ended up with Mac headers, e cutout and flowmaster exhaust with a hooker aerochamber muffler. I like it.
My favorite looking and sounding is GMMG
Long tubes are Long tubes IMO, just get them ceramic coated and/or stainless...
I checked out a thread just a few moments ago where the guy bought the ceramic ebay headers, spudnick i believe is the username. Anyway, everyone questioned the fit and durability. According to him, the headers went in just fine with no major fitment issues, and have held up so far. In addition to the ebay headers, he is running the GMMG exhaust, and the car seems to sound amazing from the video i saw.
But if i pulled all the old parts out, i would make sure to have the funds in order to replace the things id have better access to...plugs ect. As far as motor mounts, do you HAVE to remove them when pulling old manifolds and installing headers? Or is that just something that most guys do because its worth replacing them while working in the area?
If you can afford them, go with Kooks though.
and no, motor mounts aren't required but you might as well do them while your in ther, I like poly mounts personally, the increase in vibration is minimal imo for how solid they make everything feel, good time to do the trans mount too.
NGK tr55's are some of the best plugs out ther for LT1's. you should get a 160t-stat and a fan switch or tune to match the fans to the temp too since your doing the plugs now so you can get them 1step colder to match. and new wires of course
Didn't the LT1 SS's come with the SLP 2OTL exhaust? If so, it's a shame it has been removed. If you're interested in running the factory catback, you could possibly find a used one, as they are no longer manufactured. You might even get lucky and find a new one on Ebay, but it would be a long shot. I know when I was looking for an exhaust, someone had a new 2OTL listed on Ebay, but it was priced higher than the GMMG.
Run the best ur pocket book can afford, although if ur not going to get serious with the mods, any aftermarket header would be better than stock.
I would HIGHLY suggest you spend the extra buck tho to get ceramic coated headers, worth every penny and u will always get compliments on them.
Good luck.
321 Stainless is best for the price. Whatever you do go with both in
stainless, if you plan on keeping the car.
LPP makes a good nicely price stainless header and duals, also Ebay has some
lower priced stainless systems, that many have had good luck with.
Coatings do burn off after time, so they are not the one time do it end of
story as many think. Buy the best you can afford. LTs and Catback can be a
onetime purchase if planned well, and be money very well spent with a little
research.
Dub
When In Doubt Do Without
I did get them jet hot coated though. Plug access is great.
I did have to dimple one of the primaries a tiny bit because one of the bolts is hard to access. Other than that, they work great.
I do not HAVE to have an exhaust system RIGHT now...so ill practice my patience and save up some $$. In the mean time ill research the hell out of good aftermarket LT1 exhaust systems.
Seems like the pacesetters are the best for both your wallet and your needs, where the Kooks are just the top of the line and priced as such. As far as going ceramic or stainless...some say that ceramic will chip and flake, and others seem to have no issues with it. Seems to me like it may be the coating process...some shops do it right and others may not. Ill research that more.
So lets say i decide on some headers....what would some of you with daily drivers recommend past the LTs? I hear that many enjoy the flow and sound of their true dual LT1's...(which is a Y-pipe with an X pipe further down, and bullits correct? Or am i just TOTALYL wrong on that..lol)
Im not planning on street or track racing my car..lol..ill have the occasional fun tho..so dont get me wrong. Im looking for good air flow and a deep, clean sound.
