im havin a day...
Old Apr 15, 2010 | 08:38 PM
twokss's Avatar
Default im havin a day...
first the transmission in my daily is locked up. Then today my 96 t/a broke. It stinks like raw fuel in the engine bay, ses light is blinking, has a miss at idle, and back fires when it has a load on it. when you put it in drive or reverse it will back fire every few seconds with out even hitting the gas. any ideas? car drove fine all day and then all of a sudden this happens. Its an automatic, mostly stock, has no cats, long tubes, o2 simulators (which the red led is blinking like crazy), msd opti, egr is still hooked up. let me know if you need any other info. thanks
Old Apr 15, 2010 | 09:29 PM
my1994z28's Avatar
Check the coil,icm,pull a couple plugs out and see what they look like.also check the hose going to the fuel pressure regulator for fuel.
Old Apr 16, 2010 | 12:35 PM
twokss's Avatar
What does icm stand for?
Old Apr 16, 2010 | 02:38 PM
JB_97ws6TA's Avatar
ignition control module
Old Apr 16, 2010 | 02:51 PM
massconfusion's Avatar
flashing ses means you have a misfire
Old Apr 16, 2010 | 02:53 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
The rotor on the opti may have become loose. It seems to be fairly common with the MSD optis.
Old Apr 16, 2010 | 02:55 PM
whytryz28's Avatar
O2 sims not working causing motor to run pig rich?
Old Apr 16, 2010 | 05:40 PM
twokss's Avatar
i was wondering that myself. i never saw them blink before
Old Apr 16, 2010 | 07:44 PM
JB_97ws6TA's Avatar
I am assuming that the o2 sims are for the downstream o2 sensor to keep from kicking a code due to having no cats. It should still have oxygen sensors in the collectors and therefore the sims would have absolutely no affect on engine performance. Flashing SES is for a misfire as stated earlier, I hate to say it as i almost never do but it sounds like the opti rotor.
Old Apr 16, 2010 | 10:22 PM
twokss's Avatar
yea it has front o2s. but the rear o2 sims never blinked before until this problem. I pretty much figured it was the opti the second this problem started. i just wanted to see if anyone had any suggestions on things to check other than the opti. looks like this car will be sitting for a while.
Old Apr 16, 2010 | 10:39 PM
BlackBird87's Avatar
Theres a link on how the test the opti while still on the car but i cant remember it someone should chine in with it
Old Apr 17, 2010 | 03:36 PM
twokss's Avatar
pulled the codes. random multiple misfire
