LT1 Crank hub wierd??
Old Apr 17, 2010 | 03:29 PM
needtransam's Avatar
Default LT1 Crank hub wierd??
Ok here is the deal i have a 96 formula that i was working on because the engine didnt want to start
I replaced the cap and rotor from the opti, replaced water pump, all plugs with ngk, starter, and some other small stuff
anyways as soon as i replaced all of that i tired to start it and it did but the belt wasnt turning so i was like wtf, i jacked up the car and the belt was coming off the harmonic balancer, so i turn off the car, took off the serpentine belt and look at the harmonic balancer and it was really loose, so loose that it was going to probably fall off but since the crank hub has a bolt on the middle that's what hold it on to the crank snout
anyways i took off the middle bolt of the harmonic balancer and the took out the crank pulley with the hub on it, seperated the pulley from the hub and tried reinstalling the hub but its loose like its not pressed in like it should be?
is there anything i have to do to install the hub in a certain way? how can i know the hub is not bad or if i damaged something else?
Old Apr 17, 2010 | 04:33 PM
old93camaro's Avatar
yea you need a hub installer you have to press it back i there
Old Apr 17, 2010 | 05:34 PM
draggin97s10's Avatar
tap it back a little with a hammer then tighten it the rest of the way with an impact. thats my installer
Old Apr 17, 2010 | 06:33 PM
jaycenk's Avatar
with a 96 man you need to be sure you din't screew up the reluctor wheel or the CPS. the hub keeps that thing pressed on the timing key way of the crank.
Old Apr 17, 2010 | 08:00 PM
jay what is the reluctor wheel or the CPS? im kinda noob so yeah and i did followed this guide of instructions on how to install it and made that installer the guide advices too
http://www.lt1engine.com/tech/remove...lt1-crank-hub/
so yeah and it didnt go in so i think i messed what you said jay
Old Apr 17, 2010 | 08:06 PM
stevo9389's Avatar
the reluctor looks like a gear with flat teeth and the CPS is the crank position sensor at the bottom of your timing cover that reads the reluctor.
Old Apr 17, 2010 | 08:09 PM
yeah i googled how can i tell i messed it up, engine is on the car and car doesnt run but i assume is because i dont have the serpentine belt on and the crank pulley
Also, when i was putting the crank hub, like it slides so easy on the crank snout i dont have to tap it or anything its like loose like i broke a seal or something im not sure what it is im really lost lol
Old Apr 17, 2010 | 08:11 PM
sounds like your hub is whored out
Old Apr 17, 2010 | 08:13 PM
when i try to put the hub, should it be like a tight fit like if i need force to get it in? or should it slide easy?
Old Apr 17, 2010 | 08:25 PM
stevo9389's Avatar
its a pressed fit and will take a little bit of effort to get it in. if its as loose as you describe it should be time to look into a replacement. even if you managed to get the bolt tight enough to prevent it from backing out a hub that loose will likely just freespin.
Old Apr 17, 2010 | 09:49 PM
jaycenk's Avatar
Here this is a good replacement and it is keyed so no matter if the crank snout is worn it wont spin. http://www.jegs.com/i/JEGS/555/51609/10002/-1
Old Apr 17, 2010 | 09:54 PM
jaycenk's Avatar
Also the reluctor is as described above by stevo and you just need to make sure it dosn't have chunks missing out of it lol. You can pull the CPS and look through the CPS hole with a flash light and turn the crank and inspect it. At the same time you can look through the front hub seal and make sure it is seated on the timming gear keyway. If you buy the jegs hub, You will need to buy a crank key for it. It wont come with one.
Old Apr 18, 2010 | 10:35 AM
Low N Slow's Avatar
Having the belt and pulley off won't stop it from running, I would try nto get it running before I worried about fixing the crank hub.
Old Apr 20, 2010 | 11:42 AM
This are some of the images i took, i decided to take everything apart, car is throwing uhmm i forgot some of them put it was
p0335, p0336, p0100, p102, p1642, p1???(i forgot i know it starts with a p1 something about timming and high electricla load or something)
Old Apr 20, 2010 | 11:49 AM
RamAir95TA's Avatar
Your hub is shot and you need a new keyed up (link posted above).
Old Apr 20, 2010 | 12:31 PM
so hub is bad o i see thanks
Old Apr 21, 2010 | 01:05 AM
jaycenk's Avatar
LOL yea what is done to that engine? That timing set isn't stock. Thats the GMPP hd set. How does the crank snout look? I think you need to mic it and make sure it isn't so worn down that the hub wobbles. Pull that reluctor and see what the size diff is where the reluctor sits.
Old Apr 21, 2010 | 12:11 PM
i bought the car for really cheap cause it had several issues so im not sure if its stock or not but to me its stock i guess, but im not an expert or anything and havent really had it running for long so i cant tell how fast it is vs stock
anyways, do you mean that the timing isnt stock like they upgraded for performance or is there a good reason to upgrade to the GMPP hd setup you mentioned?
Im not too familiar with LT1 so im learning my way as i take this car apart lol, do you guys know why my car is throwing a timing code its something that starts with "p1" but not sure what it is?
can a bad placed crank sensor cause the car not to start? or its just a sensor and the car should start?
Old Apr 21, 2010 | 05:06 PM
so can anyone tell me?
Old Apr 22, 2010 | 12:03 PM
bump......
